Go to Post you know you are addicted to first when u crave sprockets for breakfast! - Jones571 [more]
Unread 17-01-2017, 11:58
WhiteBoySwag's Avatar
WhiteBoySwag WhiteBoySwag is offline
FRC #6398 (Kilo-Bots)
Rookie Year: 2017
WhiteBoySwag is on a distinguished road
Climber Gear Boxes
So as we know, a spool with velcro seems to be a popular strategy for now as we get all the legalities sorted. For those that are using this design or something similar, I was wondering what gearing ratio and motor you all are using and what would be best for a full weight robot?
Unread 17-01-2017, 12:15
ARampantBrian ARampantBrian is offline
AKA: Brian Wyatt
ARampantBrian is on a distinguished road
Re: Climber Gear Boxes
For what your team specifically needs as far as ratios and motors, I would suggest you use JVN's Mechanical Design Calculator (most updated here: https://www.chiefdelphi.com/media/papers/3188). If you download the most recent file, it will give you an excel spreadsheet with many different tabs. I would suggest using the "linear mechanism" tab to find out exactly what the best solution is for your specific team.
Team 829 : The Digital Goats, Captain/Driver (2013-15)
Area 5188: Classified Robotics, Mentor/Coach (2015-17)
Team 829: The Digital Goats, Mentor (2017-????)
Mechanical Engineering | Class of 2019
"The difference between a successful person and others is not a lack of strength,
not a lack of knowledge, but rather a lack in will." —Vince Lombardi
Unread 17-01-2017, 15:24
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As posted above!
Start with the motor (or a small slate of candidates), then figure out a gear ratio required.
To figure out the motor, calculate the power you want from it. In the case of a steady climb, power = weight * height / time. If you do weight in pounds, height in feet, and time in seconds, know that a ft-lb/s is about 1.35 watts (or for mental math, 3 ft-lb/s is about 4 watts).
Look at the power output of various motors. Try to find a motor where the power at maximum efficiency is close to the desired power. If none work, try two of these motors. Then, go back to the JVN calculator and try out those motors and look for the best gear ratio. Remember that the key things are that you do not trip your breakers (draw way more than their rating for any length of time) or burn up your motors (run them at inefficient slow speeds or stall). Gear ratios will have to be calculated separately for different motors, even if they have similar power because they run at different speeds.
Unread 17-01-2017, 21:16
qscgy's Avatar
qscgy qscgy is offline
The Last Airbender of 449
AKA: Sam
FRC #0449 (Blair Robot Project)
qscgy will become famous soon enoughqscgy will become famous soon enough
We're using a Mini CIM on a VersaPlanetary at somewhere between 30:1 and 50:1 (haven't decided yet; both are fine). The VersaPlanetary is rated for this kind of torque output, and it will lift our robot in about 5 seconds.
Unread 18-01-2017, 07:40
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Shameless plug here. If you aren't sure what motor(s) and reduction to use for your climber (or any mechanism), check out the spreadsheet calculator I just posted here. It lets you vary motor type & number, force, and moment arm and calculates the reduction that will put the motor at peak power output. Then you can check the top speed and see if the chosen motor is strong enough or you need a stronger motor.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
