Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
  #31   Spotlight this post!
Unread 17-01-2017, 17:21
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Re: Why the low Gear love
Originally Posted by Cory View Post
Averaging 6 gears per match would make you one of the top 5-10 robots in the world. Top robots in 2011 were hanging ~6 tubes on average in teleop. topping out at probably 8. And that was with a more open field, a protected scoring zone, and the ability to sit in the protected zone and grab tubes that were thrown cross field to you.
Others brought up good points but one huge factor is that making an effective gear scorer is arguably a lot easier to make than making something that scores tubes at tall various heights(and sometimes over another already placed tube). I think the shear reduction in the barrier of entry will make 6 gear averages a lot more common. Maybe I'm wrong and most regionals will be decided on gears alone but I hope that I'm not.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
  #32   Spotlight this post!
Unread 18-01-2017, 00:57
pmattin5459's Avatar
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Originally Posted by mrnoble View Post
One way to attempt to overcome the point values that Kevin rightly pointed out is to design a very efficient gears-only bot. A team that can consistently cycle rapidly and get three rotors turning on their own would do alright. This would require a ton of automation and driver practice, but I don't think that the only top-level bots we see will be ball shooters. Someone, somewhere is going to break gears.
I think that there should be more focus on designing these sorts of bots. I also feel that vision tracking is a must on a top gearbot, as otherwise lining up will probably be challenging (I know from experience it's a lot harder to do these sorts of things than it looks, especially with a drivetrain that can't strafe). Two such bots would be nearly unstoppable, especially with the potential addition of defense, climbs, or a fuel bot.
For example (in elims):
2 bots, 6 gears each: 180 + another 20 pts if another auton bot + additional 100 pts for 4 rotor bonus.
Add another 90 pts (40 pts + 50 bonus for 40kpa) for an ideal fuel bot.
We end up with 390 pts. Up to 540 with three climbs. Good gearbots that can score 6 gears each + climb make up the majority of the points with this strategy, with the fuel bot bringing the cherry on top.
This is an ideal scenario, but it illustrates what a championship alliance may be able to accomplish with good gearing.
  #33   Spotlight this post!
Unread 18-01-2017, 06:16
Michael Hill's Avatar
I'm predicting a lot of teams are putting too much faith in the little hook on the end of the spring. In our testing with the "official" spring (with team stand), if the gear was placed less than half way on the spring, the pilot would have to pull up rather slowly because the spring can deflect a large enough amount to make the gear want to slip off.
  #34   Spotlight this post!
Unread 18-01-2017, 07:43
Gdeaver Gdeaver is offline
FRC #1640
I have to agree with Hill. We received our McMaster spring last nigh and it is not as stiff as I thought it would be. An active mech that pushes the gear in should have no problem. A passive mech that only stets the gear at frame perimeter is very touchy. Pilots, pull smoothly. Placing any further back is risky. If a gear is dropped will doing this makes that station unusable. A team can take the penalty and move it. If they move a second dropped gear is that a yellow card? A third a red card? Gears are not easy. Balls are not easy. This is going to be a wild dynamic game.
  #35   Spotlight this post!
Unread 18-01-2017, 07:53
Raysaran Raysaran is offline
AKA: David Yang
FRC #0226 (Hammerheads 226)
Raysaran is on a distinguished road
I think one of the things that people overlook is the defense capabilities on the gear. It's only 5 points for a typical foul and 140 points for the last gear. There's going to be incredibly aggressive defense against that last gear, and if you don't manage to place that last gear you have just wasted time on the other 5.
  #36   Spotlight this post!
Unread 18-01-2017, 08:28
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
As teams start the integration process I think many will realize the true difficulty of fuel. These balls aren't small relative to the robot and holding a large amount while still being able to properly index and feed them consistently to a shooter at a high rate of fire is going to be difficult.
I'd bet many teams at this point have prototyped shooters capable of firing 5+ balls per second but haven't spent nearly as much time feeding the balls at that rate. With limited space this year stacking just 10 balls for auton is difficult to package in a "do everything robot"
A case study we often looked at on my team was 254's 2013 robot. It was by all accounts a great "do everything" robot, good shooter, good intake and a sweet climber but it's indexing mechanism held it back severely in the upper levels of competition due to its relatively low rate of fire. This was probably a result of limited options in the packaging/integration stage of design. In the end much simpler robots were able to be more competitive.
My prediction is a lot of upper middle tier robots will shoot at a high rate of fire with low consistency due to poor feeding which may be fine for teleop but will struggle in auton or shoot 3-8 indexed balls at a high rate of fire and then significantly slow down as un indexed balls feed into the indexing system. Although there will definitely be teams who are all able to overcome this.
2016: FRC 865 Mentor
  #37   Spotlight this post!
Unread 18-01-2017, 09:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You're waiting till the last gear? You must be very confident in your defender(s). If I'm otherwise ahead (because I gave up on gears and fueled at 3 rotors), I'd throw 2-3 robots into defense with 3 gears left. If you can lock them down to 3 gears left with 15-20 on the clock, you can pull off and climb with reasonable confidence that they're doomed.
Unless 4 rotors becomes utterly mundane and easily achievable, gear heavy alliances are going to have to get creative to keep opponents in the dark about just how many gears they have remaining.
  #38   Spotlight this post!
Unread 18-01-2017, 09:38
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Originally Posted by mman1506 View Post
My prediction is a lot of upper middle tier robots will shoot at a high rate fire with low consistency which may be fine for teleop but will struggle in auton or shoot 3-8 indexed balls at a high rate of fire and then significantly slow down as un indexed balls feed into the indexing system. There will definitely be teams who are all able to overcome all this though.
Completely agree with your analysis. Teams that haven't been using CAD to integrate systems from the beginning are going to find themselves with small hoppers, poor indexing systems, and most will be better off just avoiding Fuel when it comes time for their events.
On the other hand, if you've been planning your systems from the beginning, and have utilized CAD effectively, then it isn't terribly difficult to maintain a large hopper, and set up an effective indexing system. My question becomes, how big of an indexing system will separate great Fuel robots from good and poor Fuel robots. Will the top teams be able to empty their 120 ball hoppers in 12 seconds? Or will they choose to go with shorter bursts of rapid fire shooting (say 20 Fuel in 2 seconds) and just mix Fuel scoring into their typical Gear cycles.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
  #39   Spotlight this post!
Unread 18-01-2017, 09:41
AKA: Patrick Mattin
Rookie Year: 2015
Not sure how possible a 120 fuel hopper is. I'd say around 40-50 would be about the max you could store. Inevitably someone will prove me wrong, however.
  #40   Spotlight this post!
Unread 18-01-2017, 10:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Going to throw this out there just in case you mis-read point values (like I've done in the past). The 40kpa threshold gives a 20 point bonus, not 50, according to table 4-1 in the manual. As far as I can tell, it is the only place in the manual which states the point value of the threshold.
2017 Scoring Model
CAD Library | GitHub
  #41   Spotlight this post!
Unread 18-01-2017, 10:36
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
CAD + math says it's very possible. I don't think we'll keep our 120 Fuel hopper though in favor of a slightly smaller hopper with a faster indexing system. I will say that in order to have a large hopper size, you're giving yourself less room for your gear mechanism, and your climber. Teams have to determine if these tradeoffs are worth it.
Reveal Video
White Paper
  #42   Spotlight this post!
Unread 18-01-2017, 10:41
AKA: David Yang
No you're pretty right, I don't think you can get more than 50-60 unless you are only a shooter bot. We've tried many ways to improve storage capacity as well.
  #43   Spotlight this post!
Unread 18-01-2017, 10:53
AKA: David Yang
My intention wasn't on waiting till the last gear, but rather making sure that last gear does not get scored as a primary game objective against a gear focused alliance. I was trying to emphasis the problem with having a gear only alliance, is that it is incredibly difficult to get 12 gears even with mediocre defense. Assuming your drivetrain operates at a 10ft/s when traversing the field, not accounting for defense, each robot will take around 20ish seconds to place a gear. Capping the best gear robots at 5-6 gears. Playing defense around the feeder station, where you have significant vision advantage, is incredibly easy, you could easily knock out 2-3 gears from the opposing alliance even if you have mediocre unpracticed drivers just by getting in their way. Obvious this speculation is alliance dependent and is incredibly situational based on the pick/strategy situation. As a fundamental rule having a good flywheel shooter is essential in high level matches based on how the gear points scale. It will be the difference maker, assuming climbing capabilities on both alliances are similar. It's an interesting prospect because for once, diversifying your interests in FIRST is actually a good thing, something that was not the case for previous years. There is a high-risk high reward element coming from hitting that 4 rotor threshold, and a very intense game of cat and mouse is going to come from either the defending alliance or the offensive alliance. Regardless, my money is on the cat.
  #44   Spotlight this post!
Unread 18-01-2017, 17:24
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
FRC #0900
Rookie Year: 2015
KJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud of
Originally Posted by JesseK View Post
You just need 900's game piece vision tracking. Then 2-gear and 3-gear autos are totally doable .
Or just street number, uh, robot number/bumper detection https://static.googleusercontent.com...hive/42241.pdf
Yep, totally practical
