Go to Post I have long since stop trying to predict what the GDC will do. - FrankJ [more]
Unread 18-01-2017, 10:32
question question is offline
FRC #2472
question is an unknown quantity at this point
how to use USB connection from arduino to roborio?
I am attempting to use the arduino as a coprocessor for camera tracking with the pixy camera, my code is here https://www.chiefdelphi.com/forums/s...d.php?t=153849
Basically I need to be able to send one byte to the arduino and have the arduino respond with a different byte, I have had issues finding example code that reads and responds with data from the USB port on the roborio. I would like to do this without a logic converter like rioduino. I am open to suggestions for sending and receiving data
Unread 18-01-2017, 13:07
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
Re: how to use USB connection from arduino to roborio?
It may be cleaner to just use a more direct protocol supported by the RoboRIO instead of USB (e.g. SPI, I2C, RS232). Otherwise, WPILib looks like it has a SerialPort class with Port enums for USB; have you tried that?
Unread 18-01-2017, 13:11
FRC #2472
I tried i2c but whenever I tried to send/receive data from the arduino the transaction fail
Unread 18-01-2017, 13:39
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
for I2C the arduino needs to be the slave (this is possible using the Wire library)
for the RS232 port on board the roboRio, there is default debug data spewing out of it that needs to be disabled (I don't have a link handy)
search here on the forum for kSerial, I recall a number of posts talking about this.
