Go to Post It's official: we've run out of things to talk about. - Jessica Boucher [more]
Unread 17-01-2017, 10:52
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Intake Conveyor Ideal Speed
Originally Posted by wilsonmw04 View Post
you want the linear speed of your intake to be faster that you can drive forward. One of my build members, now an alum, has a rule of thumb that it should be twice as fast as your drive. Once you get it there, you can tweak it to suit your needs.
Second this.
Every ball intake I ever designed had a linear speed that at least matched our robot in high gear forward speed. This allows all the balls to clear the intake at the speed you're travelling so you don't start plowing them and pushing them out of the way.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 17-01-2017, 11:50
NoshBrooks's Avatar
NoshBrooks NoshBrooks is offline
AKA: Noah Brooks
FRC #3620 (The Average Joes)
Team Role: Student
Rookie Year: 2016
NoshBrooks is an unknown quantity at this point
Originally Posted by Skyehawk View Post
Mach 10
on the exterior 3" wheel, that would be over 71000 RPM. Scary.
Unread 17-01-2017, 11:56
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Originally Posted by Peter Matteson View Post
Second this.
Here's an article that was done about an intake that was designed for the 2014 game that touches on this same concept, along other tips for designing an intake.
http://www.buildblitz.com/team-copioli-intake-design/
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 17-01-2017, 17:45
Jrizo's Avatar
Jrizo Jrizo is offline
FRC #4335 (Metallic Clouds)
Jrizo is an unknown quantity at this point
Originally Posted by cadandcookies View Post
You intake should command that the game pieces it touches enter your robot, not lightly suggest that they do.
+1
2012 Rookie Inspiration
Dallas Regional
Unread 17-01-2017, 17:47
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Mach 10
Why not Warp 10 ?
Last edited by gerthworm : 17-01-2017 at 17:48. Reason: thought of a better and hopefully less snarky joke
Unread 17-01-2017, 17:57
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
https://youtu.be/kXjiOVkhPv8
Here's a little video of a prototype we made, it's pretty fast but it could be even better once the compression distance is fixed right and belts are tightened.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 18-01-2017, 10:35
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
So just to be clear...
We are planning on using 1" diameter rollers with belts on them, and a 10fps drivetrain. We therefore are shooting for 15fps linear speed on the belts, which would mean a roller speed of ~3400 RPM. Does this seem right/plausible/safe?
*We are using 2" wide urethane orange belts with 3D printed crowned pulleys on the drive axle.
Unread 18-01-2017, 11:14
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
I have your RPM's at 3400. someone check my math. But that's fast. try a larger roller.
Unread 18-01-2017, 11:17
RoboChair's Avatar
AKA: Devin Castellucci
It looks ok to me based on those numbers. You can always change the gearing later. If it's running that fast you will not need very much compression to move the balls. The speed is fine, but make sure you are not at risk of stalling(when you test).
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 18-01-2017, 11:27
dkavanagh dkavanagh is offline
FRC #0578 (Red Raider Robotics)
Rookie Year: 2015
dkavanagh is an unknown quantity at this point
Originally Posted by Crew Cox View Post
So what I'm getting is fast as possible without;
Breaking/slipping a belt
Burning up/ stalling a motor
Obtaining liftoff?
I don't think liftoff should be ruled out.
Unread 18-01-2017, 11:32
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by JamesCH95 View Post
... no one has ever said 'my intake can collect [game element] too quickly.'
This is good advice.
It is also important that your FUEL elevator be fast enough to keep up with your intake, so FUEL doesn't jam. My team made that mistake in 2012.
Richard Wallace
since 2003
Unread 18-01-2017, 11:58
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Obtaining liftoff?
When our intake grabbed a boulder last year the robot jumped, achieving momentary liftoff. it was perfect.
Make the game piece disappear from where it is on the floor to someplace inside your robot.
2016 Central Illinois Winner. Curie Division finalist
Unread 18-01-2017, 12:10
MikeDaigle MikeDaigle is offline
FRC #6325
MikeDaigle is an unknown quantity at this point
Hello all and thanks for reading.
For our fuel intake and shooter feed-conveyor we will likely be using 1 1/2 in. Aluminum rollers and 1 inch wide orange belting from McMaster Carr.
We will also likely be using a 775 pro with a versaplanetary to power both.
This said, does anyone have a approximate ideal spead for the belts to be moving?
Sent from my A0001 using Tapatalk
Unread 18-01-2017, 12:24
ShIfTiNgBoT's Avatar
ShIfTiNgBoT ShIfTiNgBoT is online now
AKA: David
FRC #0649
ShIfTiNgBoT is on a distinguished road
Talking Re: Intake Conveyor Ideal Speed
I would use a vex planetary gearbox so you can adjust your reduction ratio after building the robot. Honestly, I think you'll want a medium speed, but...
Unread 29-01-2017, 13:43
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
Good discussion,
I'm thinking that we're going to use a 10:1 Versa Planetary reduction with a 775 for our intake and elevator.
With 31 RPS, I think we'll be intaking fuel pretty fast.
Although I'm worried that we wont have enough power to lift palls up our elevator. Any experience with this?
Also, if we have wheels on our roller (1/2 shaft) how would I incorporate them into my calculations? Specifically on JVN.
