Go to Post The more women we have as 'rock stars' in FIRST, the more girls we'll see celebrating math and science and the doors they can open. - JaneYoung [more]
Unread 18-01-2017, 11:42
codeman73 codeman73 is offline
FRC #1024
codeman73 is an unknown quantity at this point
pixy serial byte stream sometimes offset by a byte?
We are reading the serial stream with I2C. We've got the serial protocol figured out and have been able to decode the object data, most of the time. But sometimes it seems like the bytes in the data stream are offset by a byte. We could deal with it, if they were offset to the right, i.e. preceeded by a zero. Then we could just skip the first byte. But it's the other way around. It looks like the first byte we read is the sync word, but truncated.
For example, in a correct stream, we see the following:
0xaa55,0xaa55,checksum,signature, etc
But instead we see
0x55aa,0x55-then first byte of checksum
Yes we know about the little-endian-ness and are reading that correctly.
I searched a bit here first and found http://www.cmucam.org/projects/cmucam5/wiki/RoboRIO. The RoboRio code there seems to handle a similar condition. They look for
PIXY_START_WORDX 0x55aa
instead of the expected
PIXY_START_WORD 0xaa55
and then they just read a byte. But then wouldn't you be losing that first sync word, or everything following that would be off by a byte?
Any suggestions?
