Go to Post I WANT to see teams succeed. - Steve W [more]
Unread 18-01-2017, 10:23
beardo17 beardo17 is offline
FRC #6121
beardo17 is an unknown quantity at this point
No Robot Code
We are having troubles with our robot code showing up on our robot. When we run it, the compiler says build successful but the driver station says no robot code and the comms light on the roboRIO is solid red.
Our code is on Github: https://github.com/beardo17/6121-2017
Last year we had a similar issue but I don't remember how we fixed it. Any help would be much appreciated.
Unread 18-01-2017, 10:36
question question is offline
FRC #2472
question is an unknown quantity at this point
Re: No Robot Code
My team had a similar issue, turned out the roborio did not correctly get imaged even though the current image on the imaging tool said the correct image, Try reimaging and reinstalling java to the roborio.
Unread 18-01-2017, 10:43
FRC #6121
Re: No Robot Code
We did that. We have the latest image and firmware and Java on the roboRIO. We also Updated the eclipse plugins and redownloaded the update suite.
Unread 18-01-2017, 11:52
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: No Robot Code
You are using static initialization. This means you do not know what order Objects are going to be created in. For example, in your DriveSubsystem on line 19 you call Robot.oi.getX(). Robot.oi is null and has not been created yet.
The easiest way to fix this is to create your robot project with RobotBuilder.
Unread 18-01-2017, 11:54
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: No Robot Code
if the comms light is red, it has no way to know if there is code or not. fix comms first!
Unread 18-01-2017, 11:56
FRC #6121
I forgot to mention the comms is green in the driver station. And last year's competition code works just fine.
Sent from my iPhone using Tapatalk
yuval092 yuval092 is offline
FTC #11229
yuval092 has a little shameless behaviour in the past
Re: No Robot Code
wat
Unread 18-01-2017, 11:57
AKA: אוסטין
Re: No Robot Code
Not quite right. Take a look at this document: http://wpilib.screenstepslive.com/s/...uick-reference
Unread 18-01-2017, 12:05
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: No Robot Code
If DriverStation doesn't show any log output and the robot program isn't running, it usually means it's crashing on initialization. To help fix the issue, you can use the debugger (right click project > debug as > wpilib deploy), or you can ssh in and do tail -f /home/lvuser/FRC_UserProgram.log to get the log output
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 18-01-2017, 12:07
FRC #6121
Re: No Robot Code
I'm not sure I quite know what you mean.. If I remove Static from it, will that fix it? (I currently don't have the robot to test on)
Unread 18-01-2017, 12:51
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
Re: No Robot Code
The problem AustinShalit is pointing out isn't so much the fact that your variables are static but more that you're not being careful about the way you initialize them. Robot.robotInit() gets called after object variable initialization, take a look at this:
Robot.driveSubsystem initialized:
driveSubsystem.x initialized from Robot.oi.getX()
driveSubsystem.y initialized from Robot.oi.getY() * (Robot.oi.getRTrigger() + 0.5)
other stuff...
Robot.robotInit() called:
Robot.oi initialized
See a problem here? In general though, the best way to work through these issues (besides implementing a better architecture/ conventions that prevent it from happening) is outlined in euhlmann's post.
Unread 18-01-2017, 13:08
AKA: אוסטין
Re: No Robot Code
other stuff...
Could not have said it better!
Unread 18-01-2017, 15:26
FRC #6121
Re: No Robot Code
Oh Yay!!! That fixed Evereything! Thank you all!!!!
