Go to Post Safety glasses may be a nice forehead protector, but thats not what they are made for. - Quatitos [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-01-2017, 19:56
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
The Spring
Finally got our spring today. We cut it to length and thought we'd share our experiences / images so other teams could find comparable items since FRC has a habit of cleaning out worldwide inventories of things.
We found the spring deflects about 7/32" when the gear is placed on the end. Here's some pictures: http://imgur.com/a/FGELI
It's pretty stiff and holds the gear, even when it's on the very end. Good luck teams!
Unread 17-01-2017, 20:58
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: The Spring
Very helpful. Thank you!
Unread 18-01-2017, 11:58
Justin Ridley Justin Ridley is offline
FRC #0118 (Robonauts)
Justin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond repute
Send a message via AIM to Justin Ridley
Re: The Spring
We got our spring in as well. See link for video showing it is in fact "springy"
https://vimeo.com/199933366
This is an E-41 spring from Century Spring cut to length. Specs match the McMaster p/n supplied. (http://www.centuryspring.com/extensi...ings-e-41.html)
It is sitting on a spring post made per drawing with exception that the diameter is a tad undersized as the diameter called was difficult to get in the spring (calls for 0.66" when spring ID is ~0.60 )
On that note, the drawing doesn't specify at all how the post is attached to the carriage. I can assume there's a 1/4" bolt and nut holding it in place, but this isn't shown. We also came across the attached picture which shows a clamping shaft collar which isn't shown in drawings or field model. Frustrating when you're trying to make field elements as real as possible.
-- Justin Ridley --
20 years
27 --> 221 --> 857 --> 118
Unread 18-01-2017, 13:32
13spangs's Avatar
13spangs 13spangs is offline
AKA: Jack Spangler
FRC #1756 (Argos)
13spangs is an unknown quantity at this point
Re: The Spring
We have had the same results as Justin when testing our spring. We foresee a lot of teams missing this part of the game. If teams follow most of the RI3D designs many teams when placing the gears will have them drop to the floor.
Unread 18-01-2017, 14:01
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: The Spring
... and without ground pickup they will block that lift
___________________
- Tennyson, Ulysses
Unread 18-01-2017, 15:26
Sparky Jell-0's Avatar
Sparky Jell-0 Sparky Jell-0 is offline
AKA: Jalaj "Jello" Sawhney
FRC #0384 (Sparky 384)
Team Role: CAD
Sparky Jell-0 is on a distinguished road
Re: The Spring
Hey, is that the real spring that will be used in competitions? If so is it possible for you to post a video of your spring and the gear being put on the spring in different ways. There is a huge debate in my team about the springiness of the spring, and I'm sure other teams are in the same situation. We've ordered the spring but it will be while before it gets here.
Unread 18-01-2017, 15:32
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: The Spring
We have the real spring, if you tell me what your looking for or if anyone else is questioning something I could post a video in about a hour but probably a little longer.
#StaySavage
Unread 18-01-2017, 15:34
Ariane Nazemi's Avatar
Ariane Nazemi Ariane Nazemi is offline
Faster than light: no left or right
FRC #5209 (Rectify)
Ariane Nazemi is an unknown quantity at this point
Re: The Spring
I agree that this would be a huge help. Justin's post above was a bit troubling considering the amount of bounce the gear will receive if placed on the end, or even dropped on the middle for that matter.
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: The Spring
Isn't that exactly what Justin's post above shows?
As Justin mentioned in his post, the spring shown in the video he posted matches the specs of the McMaster-Carr spring used on the official 2017 fields.
Unread 18-01-2017, 15:37
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: The Spring
Replicate EXACTLY what Justin Ridley did in his video above. I would love to see how the spring behaves when subjected to a gear dropping.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 18-01-2017, 15:40
Team Role: CAD
Re: The Spring
That's what we are looking for too. I've seen evidence of teams with springs like Justin Ridley's and teams that claim their springs are opposites of that. We just want to know what the springiness of the actual gear is.
Unread 18-01-2017, 15:42
Team Role: CAD
Re: The Spring
I'm still not sure because some teams are claiming that their spring is complete opposite of what Justin's post showed and we just want to be sure. Hence asking for a video of the real spring that will be used on the field. No offense to Justin, but this spring has become extremely shrouded in mystery.
Unread 18-01-2017, 15:43
Team Role: CAD
Re: The Spring
I'm still not sure because some teams are claiming that their spring is complete opposite of what Justin's post showed and we just want to be sure. Hence asking for a video of the real spring that will be used on the field. I'm imply that Justin's post is wrong, but this spring has become extremely shrouded in mystery.
Unread 18-01-2017, 15:44
Team Role: CAD
Re: The Spring
whoops meant "I'm not implying"
Unread 18-01-2017, 15:51
PayneTrain's Avatar
PayneTrain PayneTrain is offline
please put down the gun
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: The Spring
Hey Jalaj, I have the spring that matches the field part right now. I am cutting it down in to separate pieces that match the field size tonight and will be leaving one of the pieces at FIRST Chesapeake Command Central in Mechanicsville tomorrow some time after 10 AM. I've already given out the rest of the pieces to teams outside of the city (need to meet a guy halfway between here and Charlottesville tomorrow or Friday to play the hot potato game) but 384 should definitely head over to test it out for themselves if they want some hands-on time with it if y'all get a chance.
