Go to Post Woody is wearing flippers... 2014 WATER GAME! - Team23pitboss [more]
Unread 18-01-2017, 13:32
Re: Driver station has no robot communication
If you don't have user code or if your user code crashes, then you still should see the Driver Station Communications indicator go green (and the Robot Code indicator stay red).
If you can get that far (Communications=green) then you can worry about your user code.
Your IPs are fine (the radio IP doesn't matter-it's just routing if it's even in the network chain).
Check the diagnostic tab to see it the Driver Station is also pinging everything.
