Go to Post Dean's never ending fountain of denim. - kjolana1124 [more]
Unread 18-01-2017, 17:46
SpazMonkey214 SpazMonkey214 is offline
FRC #5740
SpazMonkey214 is an unknown quantity at this point
NEED HELP! H-Drive + Encoders
Hey All-
I'm on team 5740, and we are having issues with sensors. We are using a Holonomic Drive with Omni wheels and are planning on having the robot drive to the shaft and deposit a gear. To do this, we need to measure distance with encoders, but we are having trouble figuring out where we can place these encoders as well as what kind of encoders we need to use. Any help/suggestions?
Thanks
Jake, 5740
Unread 18-01-2017, 17:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: NEED HELP! H-Drive + Encoders
Encoders measure the amount of motion of a component, most commonly a rotating shaft or axle. To use such an encoder to measure distance along the floor, it needs to be mounted to a wheel rolling on the floor. Most commonly, these are mounted to the gearbox somewhere, or the motors. What gearboxes are you using? Using encoders which are known to support your gearbox will save many hours (and perhaps a whole season) of trouble.
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
The two threads linked below are a good start. They were found just by searching "drivetrain encoders."
https://www.chiefdelphi.com/forums/s...ain+encod ers
Unread 18-01-2017, 18:00
Chris86 Chris86 is offline
FRC #4064 (Inzombiacs)
Chris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to behold
So many COTS FIRST gearboxes from andymark and VEX have built in spots for encoder attachment and have mounting kits for them as well.
Alternatively, you can attach one of these http://www.andymark.com/encoder-p/am-3314.htm directly to a CIM shaft if you're not using one of those COTS gearboxes.
Those are your two best COTS, slap on to gearboxes/CIM option.
If you feel that your specific setup needs a more custom solution, provide more info and we can have a more in depth discussion about how encoders work and how to fit them into your system.
Current mentor for Team #4064
Proud former member of Team #86: Team Resistance 2007-2011
Unread 18-01-2017, 18:18
Knufire Knufire is offline
What is your wheel setup? Adding encoders to a holonomic drive is not always straightforward, as certain types have wheels that are constantly slipping. It is possible you need to add a follower wheel on your drive to mount the encoder on.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
