Go to Post At first, "water game" was funny. Then it went to silly. Now it's just dumb. Not to mention unrealistic for FIRST. - EricH [more]
Unread 18-01-2017, 18:13
VaneRaklan VaneRaklan is offline
FRC #2557 (The SOTABots)
VaneRaklan is an unknown quantity at this point
com.CTRE package does not exist
I don't know what it is I'm doing that I shouldn't be doing, or not doing that I should. I have added the jar to the build path and I made my attempt at adding it to the ant build.xml and still nothing. I can see that the package exists within the project's Referenced Libraries but I guess either the code or the build files can't see them.
Unread 18-01-2017, 18:25
beardo17 beardo17 is offline
FRC #6121
beardo17 is an unknown quantity at this point
I had to restart eclipse
Sent from my iPhone using Tapatalk
Unread 18-01-2017, 18:30
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: com.CTRE package does not exist
You shouldn't have to make any changes to build.xml. You should revert it. The eclipse build path should similarly auto-update as soon as you restart eclipse (as the above poster said). Make sure you have a CTRLib.jar in <user profile>/wpilib/user/java/lib. If not, try installing CTR Toolsuite again
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
