4296 Teaser Trailer
Check out this teaser trailer for Trident Robotics 4296 - 2017 FRC Steamworks.
https://youtu.be/mL6_tGCeZwg #It'sComing |
Re: 4296 Teaser Trailer
Can you post some closeups of the shooter? very consistent.
Can't wait to see the reveal video guys
shooting is the easy part. It's the ball sorting and feed that is the hard part.
"We're going to worlds baby."
A good shooter does not a winner make. There's still plenty of other tasks to focus on before even thinking about a win. That said, excellent shooter and great work guys! For those wanting to see more on the shooter, there are some closer shots near the end of this video. |
Very impressive! How much compression are you using with your shooter?
#7
Our shooter uses a 1:3 versaplanetary gearbox powered by a BAG motor rotating a 4in HiGrip AndyMark wheel. This combination gives us more than enough power to shoot balls. To position we're using the arc method: having an arc that gives consistant compression on the ball and depending on where the arc ends is the angle it shoots at.
Looking forward to seeing all the great designs and competition! |
#9
There is no 1:3 versaplanetary gearbox (http://www.vexrobotics.com/versaplanetary.html)
I assume you means 3:1? I'm quite surprised you got such accuracy and power with such a small motor. |
#10
I think by compression they mean the distance between the hood and flywheel. It looks close to 5 in. to me.
#11
Yes, this is the dimension I'm curious about. I assume it's something like 4.875", resulting in 1/8" of compression on the ball. Since you're using the white KoP wheel, all of the deformation should be happening on the ball rather than the wheel.
#12
We consistently use 1/4" of compression through our whole robot when designing anything that involves fuel. It seems to work pretty good, not too much stress on the motor but enough to grip the ball enough to move and shoot.
