Go to Post Okay guys I am enabling the robot. Honestly I have know idea what it is going to do. SO MOVE!! - JulieB [more]
Unread 19-01-2017, 00:07
Team3337_mentor's Avatar
Team3337_mentor Team3337_mentor is offline
AKA: Amanda Salom
FRC #6659 (Cougar Robotics)
Team3337_mentor is an unknown quantity at this point
XboxController Class vs Joystick Class for KOP Xbox Controller
Hello everyone,
We are a rookie team, and though I have mentored before, I never got a chance to work with Xbox controllers before. I'm managed to find some sample codes here and there, but I've never found a sample code that used the XboxController library. Any reason as to why the Joystick class is used over the XboxController class? Does it not work properly? I just don't want to set up the team to fail for any hidden reason that we never discover, God forbid, we learn the hard way during the middle of a match.
Regards,
Amanda Salom
FRC 6659 Cougar Robotics
Unread 19-01-2017, 00:21
Bradley Boxer's Avatar
Bradley Boxer Bradley Boxer is offline
AKA: Bradley Boxer
FRC #0303 (TEST Team 303)
Rookie Year: 2015
Bradley Boxer is an unknown quantity at this point
Re: XboxController Class vs Joystick Class for KOP Xbox Controller
The XboxController class is new this year in wpilib, so most FRC example code will be written with the API that does not include it. If you look at the source code for the XboxController class (at C:\Users\(your user)\wpilib\java\current\lib\WPILib-sources\edu\wpi\first\wpilibj), you can see that it boils down to getRawAxis() and getRawButton() calls in GamepadBase, but does the figuring out of which controller button corresponds to which index for you.
For example, the method getAButton() literally just returns getRawButton(1).
Note: I assume it works the same way in C++, as I only checked the java source code.
The opinions expressed in this post are mine and do not necessarily reflect those of my team.
Unread 19-01-2017, 00:23
AustinShalit's Avatar
AustinShalit AustinShalit is online now
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
The XboxController class is new this year. That is probably why you cannot find many code examples. Although both will work, if you are using a Xbox controller use the XboxController class. It has methods like getY(Hand) that will make your code easier to read in the long run.
Unread 19-01-2017, 00:29
AKA: Amanda Salom
Thumbs up Re: XboxController Class vs Joystick Class for KOP Xbox Controller
Thank you both Austin and Bradley. That makes much more sense. I though I was going crazy.
Amanda Salom
