Go to Post And yes. The Super Bowl is on, and I'm replying to a thread on Chief Delphi... - BobbyVanNess [more]
Unread 19-01-2017, 05:34
zbross's Avatar
zbross zbross is offline
Teacher, FRC 5113
AKA: Z. Bross
FRC #5113 (Combustible Lemons)
zbross is an unknown quantity at this point
Toughbox Hex Shaft With Magnet
I hope everyone's off to a good start to the season! My students are currently working on mounting wheels to their gearboxes using the Long 1/2" Hex Output Shaft with Magnet for Toughbox Series Gearboxes. Problem is, the magnet in the end is too long to use with the SRX Mag Encoder.
With it inserted into the gearbox correctly, the end sticks out about 7mm past the encoder mount pad. Given that the mag encoder requires that the magnet be between 0.75 and 1.5mm away from the end of the encoder, we're at a bit of a loss. Is the only option to use some spacers before the pad so that the encoder sticks way out? Or should we just say forget it, cut the end off, and install our own magnet?
Thanks!
Unread 19-01-2017, 06:13
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Toughbox Hex Shaft With Magnet
Thanks!
This is a very interesting new product. The product page does say:
Originally Posted by ANDYMARK View Post
This shaft includes a pre-installed magnet designed specifically with the E4T OEM Miniature Optical Encoder (am-3132) and SRX Magnetic Encoder (am-3445) encoder in mind.
So it most likely can be used for a Mag Encoder easily in it's stock configuration. It seems easier to make a little spacer then to do the lathe work to install your own magnet. The magnet isn't required for the E4T, so it is basically designed for the SRX Mag encoder, so should be ok to use.
This guide by CTRE
has a section on adapting the ToughBox shaft for a .25" magnet, so it might help you fix the problem that you are having or if not, it'll help you install a magnet( which will hopefully also fix your problem).
Unread 19-01-2017, 06:21
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to behold
Note that Andymark is now selling a short version of the shaft (probably a bit short, considering the long only sticks out 7mm). I'm not sure about the construction of the toughbox, but can't you just cut off a couple millimeters from the non-magnet side and push the shaft the outwards further?
Unread 19-01-2017, 06:32
pilleya's Avatar
Elec+Mech
Not really possible without some serious modification, the 1/2" hex gearbox shaft is turned down to 3/8" at the end to fit into a 3/8" round bearing. There is an E-clip which retains the shaft and also ensures good meshing of the gears( if you don't use the E-clip the shaft can fall out).
Unread 19-01-2017, 07:32
zbross's Avatar
Teacher, FRC 5113
AKA: Z. Bross
Originally Posted by pilleya View Post
...So it most likely can be used for a Mag Encoder easily in it's stock configuration...
That's what we thought as well! Turns out that it's not really made for that, in any way. Does anyone think it would work if we just chopped the magnet side to length?
Unread 19-01-2017, 07:34
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Thanks!
I wouldn't cut it. Cutting the magnet is going to be messy. I would give AM support a call and let them know what you're seeing. I suspect they can help with a fix or suggesting one.
Unread 19-01-2017, 07:44
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
I have not seen this product in person, however if the magnet is the only part too long, perhaps you can remove the magnet, then drill the hole in the shaft deeper with a standard drill in a vise (since there is already a hole) and then push the magnet down farther.
Unread 19-01-2017, 09:15
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Thanks!
Hi there!
I'm sorry that this hasn't gone together as planned for you. We're currently working on a couple hardware kits (one for encoder mount pad-based gearboxes, one for molded gearboxes) that help relocate the encoder mount points that the SRX Mag Encoder require. These aren't quite ready yet, as we're slowly converting all of our shafts to have this magnet embedded in them. In the meantime, I recommend either purchasing (or making your own equivalent,) spacer from www.aluminumspacers.com, part number #MAS8-5-7. I would also pick up some #10 shim washers from a hardware store, as the magnet placement in the shaft has an approximately 0.025" range of where it seats. The shim washers would let you fine-tune the placement of the encoder. You can check this by looking at the indicator lights inside the SRX mag encoder; it should be green if the encoder and magnet are the correct distance from eachother.
A quick note for all; please do not attempt to machine this magnet or attempt to remove it. It is a tight press fit, and clamping down on it with something like vise grips will result in magnet fragments everywhere.
Sincerely,
Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 19-01-2017, 09:23
marshall's Avatar
Originally Posted by Nick Lawrence View Post
Hi there!
Sincerely,
Nick
AM Crew to the rescue. You guys are quick.
Unread 19-01-2017, 21:26
Ptyoung's Avatar
Ptyoung Ptyoung is offline
AKA: Peyton Young
FRC #0226 (Hammerheads)
Team Role: CAD
Rookie Year: 2016
Ptyoung is on a distinguished road
Hello all,
A couple CAD members of 226 worked on designing a 3d printable spacer for the toughbox + am-0801a. Our measurements for the distance between the edge of the magnet and the gearbox were between ~7.8 mm and ~8.4 mm on our test chassis. The CAD can be found here. The spacing is 9.226 mm off of the gearbox, so it should work anywhere from 8.476 mm to 7.726 mm, we highly encourage teams to take measurements for themselves and make edits to our design.
