Go to Post It's too late to turn back - the only way is forward. Together - with a plan. - JaneYoung [more]
Unread 19-01-2017, 09:45
Raysaran Raysaran is offline
AKA: David Yang
FRC #0226 (Hammerheads 226)
Raysaran is on a distinguished road
Fuel manipulation outside robot frame without forced air
The question is simple, say you have a open hopper, and the fuel overflows your height limit. When you move you are technically controlling and manipulating fuel outside of your robot, but not using forced air. Does this violate G28 or an obvious rule that I'm not seeing?
Unread 19-01-2017, 09:57
ceb515's Avatar
ceb515 ceb515 is offline
AKA: Charlie
FRC #2607 (Robovikings)
ceb515 is an unknown quantity at this point
Re: Fuel manipulation outside robot frame without forced air
Please check the FRC Q&A, and if no one has asked this you can ask it.
https://frc-qa.firstinspires.org/
2015 - MAR Championship 3rd Place, Qualified for CMP
Blue Banners: 2010 Philadelphia Reigonal, 2014 Virginia Reigonal, 2015 Hatboro-Horsham, 2015 Upper Darby
SEE US AT THESE COMPETITONS:
Hatboro-Horsham District Event 2017, Seneca District Event 2017
Electrical Lead, Programmer, Designer, Pneumatics, Prototyping, All-Out-Geek
Unread 19-01-2017, 10:03
AKA: David Yang
I checked that it has not been asked on the QA, I will ask it, just wanted to see what other thought first, will submit Q & A post soon.
Unread 19-01-2017, 10:11
lamiet01's Avatar
lamiet01 lamiet01 is offline
Tim Lamie
FRC #4967 (That ONE Team - Our Next Engineers)
lamiet01 is an unknown quantity at this point
Q68 addressed this from the standpoint that game pieces are not part of the robot volume (https://frc-qa.firstinspires.org/qa/68). However, you probably should ask for clarification based on the subject of "controlling" game pieces as that appears to be an important distinction.
Tim Lamie
Mentor 2013 to present
FRC 4967 That ONE Team - Our Next Engineers
Unread 19-01-2017, 10:18
AKA: David Yang
Thanks!
Unread 19-01-2017, 10:24
Chris is me's Avatar
AKA: Pinecone
If you couldn't manipulate fuel outside your robot, how could you intake a ball that hasn't totally rolled into your robot volume already?
I wouldn't read into the rule more than is already there. It restricts the ways you can use forced air to move fuel, not how you move fuel in general.
