Go to Post Step 1: Get Drill Step 2: Insert 1/2"-1" bit into drill Step 3: Drill Those Speed Holes! - Adam Richards [more]
Unread 17-01-2017, 13:36
TJP123 TJP123 is offline
AKA: Tom Pospeshil
FRC #0503 (Frog Force)
TJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant future
Re: Predicting Actual High Efficiency Goal Shooting at Worlds
1 out of _50__ teams will have a median H.E.G. ball count that is >50
1 out of _80__ teams will have a median H.E.G. ball count that is >100
1 out of _500__ teams will have a median H.E.G. ball count that is >200
1 out of _the world_ teams will have a median H.E.G. ball count that is >400
Unread 17-01-2017, 13:57
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
  1. 1 out of _10__ teams will have a median H.E.G. ball count that is >50
  2. 1 out of _20__ teams will have a median H.E.G. ball count that is >100
  3. 1 out of _25__ teams will have a median H.E.G. ball count that is >200
  4. 1 out of _sideways 8__ teams will have a median H.E.G. ball count that is >400
Explanation: Indiana has roughly 50 teams in it. I could see five of those teams >50. I could see two robots at each event >100, and an event has 30-40 teams. If a team can hit >100, they can probably hit >200. As for >400, that would involve a comeback of the 2006 A-Bomb.
Hi!
Unread 17-01-2017, 15:13
dv/dt dv/dt is offline
FRC #2990 (Hotwire Robotics)
dv/dt is on a distinguished road
1.1 out of _50__ teams will have a median H.E.G. ball count that is >50
2.1 out of _100__ teams will have a median H.E.G. ball count that is >100
3.1 out of _300__ teams will have a median H.E.G. ball count that is >200
4.1 out of _1500__ teams will have a median H.E.G. ball count that is >400
Interesting that you chose median and not mean. To that, in qual rounds, at least half of your matches will have alliance partners that struggle to get 6 gears between the two of them. So will you focus on the other 6 gears for higher points or fuel?
I can see a team that is capable of shooting 150+ balls in a match as making the decision to get the fuel RP and stopping at 100 balls and then finishing the gears. But more often than not they will need to focus on gears for the higher point value and skip fuel.
Note that 100 balls is 1 RP if you get your 10 in auto, then 90 in teleop.
I've been a long term pessimist though.
Unread 17-01-2017, 15:19
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
1. 1 out of 4 teams will have a median H.E.G. ball count that is >50
2. 1 out of 9 teams will have a median H.E.G. ball count that is >100
3. 1 out of 63 teams will have a median H.E.G. ball count that is >200
4. 1 out of 420 teams will have a median H.E.G. ball count that is >400
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
Unread 17-01-2017, 15:50
AKA: Tom Pospeshil
Does it count as an edit if I change to this:
1 out of _503__ teams will have a median H.E.G. ball count that is >200
Unread 17-01-2017, 17:25
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I'll allow it. Consider your priority date intact and your guess as 503.
Dr. Joe J.
Team #88, TJ2
Unread 19-01-2017, 06:50
AKA: Dr. Joe
FRC #0088 (TJ2)
Two things.
First, no clever stats person has stepped up to say they will make an "OPR-type" statistical estimator of median High Efficiency Goal ball count so... ...another $20 gift card prize that will never be claimed
Second, how would people change their answer if instead of MEDIAN H.E.G. ball count the question asked to predict MAX H.E.G. ball count? Specifically, how would you fill in the following 8 blanks:
  1. 1 out of ___/___ teams will have a median/max H.E.G. ball count that is >50
  2. 1 out of ___/___ teams will have a median/max H.E.G. ball count that is >100
  3. 1 out of ___/___ teams will have a median/max H.E.G. ball count that is >200
  4. 1 out of ___/___ teams will have a median/max H.E.G. ball count that is >400
Your thoughts are welcome.
Dr. Joe J.
Team #88, TJ2
Unread 19-01-2017, 07:47
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
1 out of 3/2 teams will have a median/max H.E.G. ball count that is >50
1 out of 10/5 teams will have a median/max H.E.G. ball count that is >100
1 out of 100/40 teams will have a median/max H.E.G. ball count that is >200
1 out of 600/600 teams will have a median/max H.E.G. ball count that is >400
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 19-01-2017, 08:35
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Joe Johnson View Post
Two things.
Dr. Joe J.
I'm just going to submit my guess for median HEG ball count as a guess for max HEG ball count. I feel like my median guess was too high so this would make for a nice hedge of my bet.
Unread 19-01-2017, 08:40
Taylor's Avatar
AKA: @taylorstem
My estimate remains the same. If a team can hit that kind of accuracy, then that team can do it consistently.
Hi!
Unread 19-01-2017, 08:57
Raysaran Raysaran is offline
AKA: David Yang
FRC #0226 (Hammerheads 226)
Raysaran is on a distinguished road
1.1 out of _4__ teams will have a median H.E.G. ball count that is >50
2.1 out of _9__ teams will have a median H.E.G. ball count that is >100
3.1 out of _50__ teams will have a median H.E.G. ball count that is >200
4.1 out of _300__ teams will have a median H.E.G. ball count that is >400
I think the balls are light enough that doing 100 is pretty reasonably easy for many teams. If you consider the ability to just dump the 50 balls from the hopper into your robot, that cuts intake time down by a ton.
So assuming it takes 25 seconds lump sum for you to collect 100 balls, (5 seconds for dump and 20 seconds for ground pickup)
Also estimating the approximate time to shoot these 100 balls, assuming you are shooting at a moderate rate of 2 balls, you are looking at about 50-55 seconds to shoot all of the balls.
I think my estimated times and firing rates are really conservative estimates.
Basically 55 + 25 = 80 seconds.
I think a team that does 1 or 2 gears would still reasonably shoot 100, a robot just shooting balls could get close to 200.
However, getting 400 is a lot of black magic to me, someone broke something about the game to be able to score that much. I don't think you'll ever see the number that high.
Playing around with our prototypes/ some initial software control we have yet to find a way to get 100% accuracy on shooting more than 2 balls per second.
If anyone has better results/ think I really missed something important on my estimates please let me know!
Unread 19-01-2017, 09:26
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
1 out of 10/8 teams will have a median/max H.E.G. ball count that is >100
1 out of 30/20 teams will have a median/max H.E.G. ball count that is >200
No teams will have a median/max H.E.G. ball count that is >400
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 19-01-2017, 10:36
piersklein piersklein is offline
piersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the rough
1. 1 out of 10 teams will have a median H.E.G. ball count that is >50
2. 1 out of 30 teams will have a median H.E.G. ball count that is >100
3. 1 out of 300 teams will have a median H.E.G. ball count that is >200
4. 1 out of all teams will have a median H.E.G. ball count that is >400
2016 Boston Semifinalists
2016 UMass Dartmouth Creativity Award, Quarterfinalist
2015 Northeastern Quarter Finalists (6th rank)
2015 UMass Dartmouth Winners
2014 RISM Rookie Inspiration Award, Semifinalists.
2014 NorthEastern Rookie All-star, Highest Rookie Seed, Semifinalists.
2014 NECMP- Highest Rookie Seed
Unread 19-01-2017, 10:43
Aiden Jacobs Aiden Jacobs is offline
FRC #1939
Aiden Jacobs is an unknown quantity at this point
You Have 135 seconds of teleoperate period assuming you shot at 100% accuracy for the whole time (other teams feeding you fuel) at 2 balls per second you sore 270 balls+ 10 balls in auto. That is 100 points. I think barely any matches will exceed 200 balls. I think playing defense and seeing if you can prevent the gear cycles will be more valuable. especially if you can prevent all four rotors.
Unread 19-01-2017, 10:44
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Two things.
While I'm no "Clever Stats Person", I believe The Blue Alliance is going to try and use OPR on fuel scored this year per event, which could then be quite easily compounded into a median or average for each team. None of this has been accomplished yet (AFAIK) because FIRST hasn't released their API that TBA feeds off of. I'd be happy to make a quick thing to calculate this once their API is finished.
Meanwhile, my predictions are as follows.
1.1 out of _5__ teams will have a median H.E.G. ball count that is >50
2.1 out of _15__ teams will have a median H.E.G. ball count that is >100
3.1 out of _150__ teams will have a median H.E.G. ball count that is >200
4.1 out of _500__ teams will have a median H.E.G. ball count that is >400
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
