Go to Post Thank you from the bottom of our IFI controllers, The Robonauts. - Natchez [more]
Unread 19-01-2017, 14:13
KurokoP KurokoP is offline
FRC #4471
KurokoP is an unknown quantity at this point
Using encoder with Talon SRX
I have a problem with coding an Encoder that I'm using with Talon SRX. I want to get feedback from an Encoder and see if all motors are run at the same speed but I don't know how to write a code for it since I'm new at programming. Can I get an example code or more explanation about this information? Thank you!
