Go to Post When you build a practice robot, you're literally buying time. - sanddrag [more]
Unread 19-01-2017, 14:52
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Gear Drive Question
Hello all, due to some size constraints these two Versa Planetary gearboxes need to be mounted in this awkward position. One is 1:100 and the other is 1:35 and the gears on them are 20:60. Does anyone see this as a problem? As long as the ratios end up the same I believe it should be fine. Thoughts?
https://drive.google.com/open?id=0B6...GgxZDUwS0p6RTA
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
