Go to Post Just remember to be as transparent and inclusive as you can. - DonRotolo [more]
Unread 19-01-2017, 14:55
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Gear Drive Question
Why not run the dual motor input from VexPro or switch to a more powerful motor such as the 775pro?
You may also want to consider using belt or chain to transfer power, it may open up some better options for you.
Unread 19-01-2017, 14:56
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
The added length sticks outside our frame perimeter. We want the added safety of being able to stall the motor for more than 1/4 of a second without it burning out.
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 19-01-2017, 15:01
Build Captain
I misunderstood how the Dual motor input is assembled. It looks like it will fit! Thanks for getting me to double check that.
Unread 19-01-2017, 15:12
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
I would run 2 40t gears and the same ratio on both if you are set on using bag motors. Also, in the 4 seconds it takes a 775pro to burn out, it should be possible to have a current monitoring program shut down that mechanism. Can you provide details on what mechanism this is driving? Without knowing the application its hard to determine the best solution.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
1592 (2016-2017)
