Go to Post Great. Just what we need. DHS showing up at all the regional competitions. . - dlavery [more]
Unread 19-01-2017, 14:52
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Gear Drive Question
Hello all, due to some size constraints these two Versa Planetary gearboxes need to be mounted in this awkward position. One is 1:100 and the other is 1:35 and the gears on them are 20:60. Does anyone see this as a problem? As long as the ratios end up the same I believe it should be fine. Thoughts?
https://drive.google.com/open?id=0B6...GgxZDUwS0p6RTA
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 19-01-2017, 14:55
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Gear Drive Question
Why not run the dual motor input from VexPro or switch to a more powerful motor such as the 775pro?
You may also want to consider using belt or chain to transfer power, it may open up some better options for you.
Chris is me's Avatar
AKA: Pinecone
The ratios don't work out exactly for that setup - 35 times 3 is 105:1, not 100:1. It won't be the most efficient way to get power from both motors.
Is there any reason you can't use the 2 motor VP adapter here? This seems like the perfect application for it, and it would take up less space.
Alternately, could you make both gearboxes the same ratio, and use 40 tooth gears on each to mesh them together? It's the same center to center spacing but no weird ratio combinations.
You could also use a single 775Pro for almost as much power as 2 BAGs. Any number of other solutions seem more robust and reliable than this one.
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
35*3 = 105
It might be close enough for an FRC bot, but it's definitely not ideal.
Unread 19-01-2017, 14:56
Build Captain
The added length sticks outside our frame perimeter. We want the added safety of being able to stall the motor for more than 1/4 of a second without it burning out.
Unread 19-01-2017, 15:01
Build Captain
I misunderstood how the Dual motor input is assembled. It looks like it will fit! Thanks for getting me to double check that.
Unread 19-01-2017, 15:12
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
I would run 2 40t gears and the same ratio on both if you are set on using bag motors. Also, in the 4 seconds it takes a 775pro to burn out, it should be possible to have a current monitoring program shut down that mechanism. Can you provide details on what mechanism this is driving? Without knowing the application its hard to determine the best solution.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
1592 (2016-2017)
