Re: 2017 Dashboard USB Camera
Having the same problem here. We're using Java. Wondering if anyone got around this.
The camera won't work out of the box in Java without a little effort. https://wpilib.screenstepslive.com/s...e-roborio-2017 The LabVIEW default program includes a camera server, but C++ and Java require the user to add one themselves (it's pretty easy). Last edited by Mark McLeod : 19-01-2017 at 17:15. |
Yes, my student had done that. I'm not sure what the root problem was, but he fixed it and wrote up a nice explanation and tried to post it here. Looks like the post didn't make it. I can bug him to repost if anyone else is having the same issues.
Get him to post it.
It's always good to get closure on a successfully resolved issue. Someone will be searching for the same answer some day. |
This is just a quick post after my other one apparently didn't go through or something. I'll fix it up later, but if you stumble upon this and have more questions, feel free to contact me.
Try updating Eclipse. The WPILib has been changed significantly this year. They've stopped using NIVision in favor of OpenCV and CameraServer(cscore) libraries. This means old code is no longer compatible with the 2017 driver station. I have autoupdate on, so all I had to do was notice the little yellow box, click it, accept some license agreement of something, then click next a fewe times. You may have to manually update. Information for that can be found here. (http://wpilib.screenstepslive.com/s/...-all-languages) Then you have to reimage the roborio and reinstall java on it. Those can be found here and here. (http://wpilib.screenstepslive.com/s/...g-your-roborio) (http://wpilib.screenstepslive.com/s/...ller-java-only) Some info on the changes can be found here. (http://wpilib.screenstepslive.com/s/...8-new-for-2017) None of the old example code works, but some can be found here. (https://wpilib.screenstepslive.com/s...e-roborio-2017) |
We are having trouble getting a camera image on the 2017 Dashboard too. We are using C++ and have done everything listed in the above post. We downloaded the Intermediate Vision example to the roboRIO. On the dashboard the drop-down box lists both USB Camera 0 and Rectangle but neither of these produces any video. Any ideas?
#7
Tonight we found out that the camera works fine when the driver station is run on our programming pic but not on the Classmate. The only change to the Classmate this year has been the FRCUpdateSuite 2017.0.0.
#8
What is the minimum necessary to display two HD3000 USB cameras on the Dashboard using LabVIEW?
