Go to Post Have I ever poked fun at you? OK, maybe Heidi. and JVN. And Dave Lavery. and Andy Baker. and .... all right, I guess I deserve it. - Gary Dillard [more]
Unread 17-01-2017, 12:41
Team2909 Team2909 is offline
FRC #2909
Team2909 is an unknown quantity at this point
Exclamation 2017 Dashboard USB Camera
Prior to installing the 2017 Update Suite, all we had to do was click the dropdown box and select which camera we wanted. We are using a Logitech USB Webcam. Now with the new Dashboard, when we click the arrow, nothing shows up at all. Can someone please tell us what we are doing wrong?
Unread 17-01-2017, 12:56
Re: 2017 Dashboard USB Camera
Try this sequence:
  1. Plug in camera, power up roboRIO & radio
  2. On the PC start the Driver Station
  3. Wait for Communications and Robot Code to go green
  4. Wait for camera 0 to appear as a camera selection (it will take a minute)
  5. After selecting camera 0, if the image remains blank, try hitting the Reset button on the roboRIO (or use the Driver Station Diagnostics tab to choose Restart Robot Code)
  6. Wait for everything to come back
  7. Wait a couple of minutes more for an image to appear.
Unread 17-01-2017, 12:59
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Just wondering, does this mean it can support multiple cameras more easily than last year?
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 17-01-2017, 13:01
Easier in the sense that the default dashboard comes with two independent camera windows.
You still need to write (duplicate) code to send a second camera stream.
Bandwidth for two cameras still needs to be a consideration, especially with USB cameras.
Unread 17-01-2017, 13:08
Roboter
Rookie Year: 2015
Will keep in mind. Thanks for the explanation!
Unread 17-01-2017, 13:43
FRC #2909
Try this sequence:
After doing all this, it still says, "No Camera Selection"
Unread 17-01-2017, 13:55
What language and user program are you running on the roboRIO?
Unread 19-01-2017, 16:19
RossMN RossMN is offline
FRC #4229
RossMN is an unknown quantity at this point
Having the same problem here. We're using Java. Wondering if anyone got around this.
Unread 19-01-2017, 16:47
Have you implemented an image server on the roboRIO?
The camera won't work out of the box in Java without a little effort.
https://wpilib.screenstepslive.com/s...e-roborio-2017
The LabVIEW default program includes a camera server, but C++ and Java require the user to add one themselves (it's pretty easy).
Unread 23-01-2017, 09:17
FRC #4229
Yes, my student had done that. I'm not sure what the root problem was, but he fixed it and wrote up a nice explanation and tried to post it here. Looks like the post didn't make it. I can bug him to repost if anyone else is having the same issues.
Unread 23-01-2017, 09:26
Get him to post it.
It's always good to get closure on a successfully resolved issue.
Someone will be searching for the same answer some day.
Unread 23-01-2017, 11:44
Murphy's Avatar
Murphy Murphy is offline
AKA: William "Murphy" Henning
FRC #4229 (Magnetech)
Rookie Year: 2016
Murphy is an unknown quantity at this point
This is just a quick post after my other one apparently didn't go through or something. I'll fix it up later, but if you stumble upon this and have more questions, feel free to contact me.
Try updating Eclipse. The WPILib has been changed significantly this year.
They've stopped using NIVision in favor of OpenCV and CameraServer(cscore) libraries.
This means old code is no longer compatible with the 2017 driver station.
I have autoupdate on, so all I had to do was notice the little yellow box, click it, accept some license agreement of something, then click next a fewe times.
You may have to manually update. Information for that can be found here. (http://wpilib.screenstepslive.com/s/...-all-languages)
Then you have to reimage the roborio and reinstall java on it. Those can be found here and here. (http://wpilib.screenstepslive.com/s/...g-your-roborio) (http://wpilib.screenstepslive.com/s/...ller-java-only)
Some info on the changes can be found here. (http://wpilib.screenstepslive.com/s/...8-new-for-2017)
None of the old example code works, but some can be found here. (https://wpilib.screenstepslive.com/s...e-roborio-2017)
Unread 24-01-2017, 08:54
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
We are having trouble getting a camera image on the 2017 Dashboard too. We are using C++ and have done everything listed in the above post. We downloaded the Intermediate Vision example to the roboRIO. On the dashboard the drop-down box lists both USB Camera 0 and Rectangle but neither of these produces any video. Any ideas?
Unread 24-01-2017, 19:23
Tonight we found out that the camera works fine when the driver station is run on our programming pic but not on the Classmate. The only change to the Classmate this year has been the FRCUpdateSuite 2017.0.0.
Unread 25-01-2017, 18:54
xisybyl xisybyl is offline
FRC #3648
xisybyl is an unknown quantity at this point
What is the minimum necessary to display two HD3000 USB cameras on the Dashboard using LabVIEW?
