Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 19-01-2017, 19:12
SnowCats SnowCats is offline
FRC #6408 (Syntechs)
Rookie Year: 2017
SnowCats is an unknown quantity at this point
Post Polycarbonate/Plexiglass Ruling
I was looking through the game manual for this year's competition and I couldn't find anything about the amount of polycarbonate/plexiglass you are allowed to use
Is there a rule on how much you can use?
If so, how much?
Unread 19-01-2017, 19:14
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Polycarbonate/Plexiglass Ruling
If so, how much?
You can use as much as you like as long as it is under the allowed total cost of $4000. Probably best to stick to polycarbonate for robot parts to avoid disappointment.
Unread 19-01-2017, 19:15
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
If so, how much?
There is no limit to how much polycarbonate you can use on your robot. The only rule that applies would be the 120 lb robot weight limit. Be careful how you budget your weight!
edit: ^^^ also the $4000 robot budget limit, and the $400/part limit
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 19-01-2017, 19:22
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
This raises the question: if you built your entire 120lbs robot out of polycarb, would you exceed the $400 part limit (if it were one solid block) or $4000 total cost limit (if it were laminated sheets)? Someone with too much free time want to do the math?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 19-01-2017, 19:34
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
A solid block of polycarbonate would cost less than an equivalent block of 7075 aluminum, I think. We can ask Poohbear.
http://www.angelbotics.com
Remember why you're doing this.
Unread 19-01-2017, 19:37
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Or just ask ask a team that basically does build their entire robot out of polycarb.
Reveal Video
White Paper
Unread 19-01-2017, 22:47
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Ok learn from our mistakes!! DO NOT use Plexiglass as an electronics board! We had ours made of Plexiglass last year, and by the end of our third time on the field, it was falling apart. By the time eliminations came around, we were on the field with an electronics board held together mostly by duct tape. Poly carbonate is definitely the better choice.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 19-01-2017, 22:57
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
This. So many people just call clear plastic "plexi" or "plexiglas"-- whether it's the right thing or not. For competitive robotics, it is just about always the wrong thing.
Also, since nobody explicitly stated what will go wrong:
Lexan basically doesn't shatter. They use specific compositions of it for bulletproof "glass" for this reason. You can even cold-bend the stuff (though I wouldn't generally recommend it) and depending on the use it can be fine. Acrylic on the other hand... well, drop it or hit it with something or try to bend it and see what happens. It shatters. Something into sharp shards. A quite undesirable characteristic for robots. So, polycarbonate, Lexan, or Makrolon are generally good for robot use. Acrylic, Plexiglas, Acrylite, Lucite or Perspex = bad news.
To reiterate everyone else:
Make sure what you are using is polycarbonate and not acrylic or it may very well literally shatter your dreams.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 19-01-2017, 23:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
50lbs of PC resin = $175 so $420 for 120 lbs. I'm going to assume we use the bulk price of the resin. Otherwise your robot is free cause each pellet < $5. Actually, I think it's costed at the cost of the smallest amount you can actually buy that covers what you used. So if a carbon fiber resin only comes in $1000 drums, you're out of luck.
According to midwest steel supply, a 24"x24"x2" plate of 7075 regularly costs $440 and weighs in at 116lbs.
Unread 19-01-2017, 23:12
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
You'd need a 5-axis mill and hexagonal wheels too.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 19-01-2017, 23:15
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
That being said, (and all of it accurate) you can also weaken polycarbonate significantly with some chemicals. Threadlock in particular can make even polycarbonate brittle.
Unread 19-01-2017, 23:24
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
We made the fan/lid over our electronics last year out of plexiglass. The first defense we crossed, it broke.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 19-01-2017, 23:43
Eryl2000's Avatar
Eryl2000 Eryl2000 is offline
FRC #3024 ("My Favorite Team")
Eryl2000 is on a distinguished road
Haha yes, I loved that thread!
Unread 20-01-2017, 00:37
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
You'd need a 5-axis mill and hexagonal decagonal wheels too.
Fixed that for you. Also, they need to be arranged holonomically.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 20-01-2017, 08:50
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
To restate what others have already said.
Plexiglass is a brand name of acrylic.
Lexan is a brand name of polycarbonate.
They both have their advantages, but acrylic is brittle compared to polycarbonate.. You should avoid using for shields and structural partc. It is nice for fish tanks if we ever have a water game. One easy test to tell acrylic from poly. Hit a piece hard against a table top. If it cracks or shatters it is probably acrylic. Wear your safety glasses. So in the robot world. Lexan=polycarbonate=good. Plexiglass=acrylic=bad.
