Go to Post We've done all the speculation we can do (some of us with less knowledge than others); let's rest our minds and keyboards and wait. - Astrokid248 [more]
Unread 19-01-2017, 19:33
SandraM6046's Avatar
SandraM6046 SandraM6046 is offline
FRC #6046 (King Tech)
Rookie Year: 2016
SandraM6046 is an unknown quantity at this point
Exclamation Battery Placement
Hi everyone,
My team was wondering if it was within FRC rules to have the battery placed horizontally. In that manual it says "The ROBOT battery must be secured such that it will not dislodge should the ROBOT be turned
over or placed in any arbitrary orientation" but does not say anything about being placed horizontally.
Would anyone be able to confirm whether the battery can be placed horizontally or not?
Thank you
Unread 19-01-2017, 19:34
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
Re: Battery Placement
Originally Posted by SandraM6046 View Post
Hi everyone,
Thank you
It can be placed horizontally or vertically given that either way it is securely fastened (as mentioned in the manual).
Unread 19-01-2017, 19:36
Rookie Year: 2016
Thank you very much!
Unread 19-01-2017, 20:09
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
It should be relatively easy to secure it. All you need to do is buy (or 3d print) one of these and then bolt some straps to the plate you're mounting to. If you already have some Velcro around, you can put together a quick one by bolting down a loop side face up and a hook side face down on opposite ends of the battery. Keep the backing on.
Unread 19-01-2017, 20:44
DonRotolo's Avatar
Back to humble
FRC #0832
Just avoid mounting it upside-down.
Also, place it so both the terminals cannot ever touch a piece of metal at the same time. That would cause a short circuit across the battery terminals, which will be a very dangerous event (as in "Flash" "Bang" "Send for Help")
Unread 19-01-2017, 21:09
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
This is in addition to making sure the battery terminals are fully insulated with electrical tape and/or heat shrink.
Unread 19-01-2017, 21:11
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I even suggest if possible try not to put it so both terminals are near the same piece of metal. On our practice chassis last year, there was an aluminum cross support that the battery sat next to (read:was strapped onto). While switching batteries once, the electrical tape around the terminals came loose and as soon as we started driving the battery arced through the cross support. It made a big blue light and a pop sound and the next second the battery had practically no charge. Luckily no one was touching the robot or someone really could have gotten hurt. After that, we made sure all of our terminals were taped up really well.
Also let this be the first reminder of the year (that I've seen) to tape your battery terminals thoroughly to avoid arcs. Last year this was an inspection point. Not sure if it is again this year, but make sure you will pass for your own safety even if it's not.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 19-01-2017, 21:19
cgmv123's Avatar
AKA: Max Vrany
It's R42.
Unread 24-01-2017, 13:46
Sandra,
Most of the manufacturers on the "allowed" list will specify that their batteries can be used in any orientation. I for one, recommend that batteries be charged only in the upright position to allow the cell gas valves to operate correctly during charge.
Double down on the suggestion that battery terminals be insulated at all times.
Unread 24-01-2017, 14:00
lukekaiser lukekaiser is offline
FRC #5547 (the talons)
Rookie Year: 2016
lukekaiser is an unknown quantity at this point
If you don't secure your battery properly you will run into complications like 5547 at about 2:30 you'll see the RED team robot attempt to clear the defensive obstacle and it literally "poops" out the battery. https://www.youtube.com/watch?v=z_MJpGp38qM
