Go to Post The only thing more tedious than following a super-long thread is following a super-long thread with the same observations on every page. - CrazyCarl461 [more]
Unread 19-01-2017, 21:54
trycatch's Avatar
trycatch trycatch is online now
FRC #5858
Rookie Year: 2015
trycatch is on a distinguished road
VersaPlanetary Integrated Encoder question
Just a trying to get a quick clarification about the VersaPlanetary encoder - I see it's the magnetic encoder.. it *looks* like the magnet is built into the top gear that's rotated by the thru-coupler, so you don't have to bore a magnet into an axle like if you were using just the encoder by itself.
1. Am I understanding this correctly? It looks straightforward but I want to be sure.
2. Is there a way to get one of these gears by itself? We have a couple of the encoders by themselves, it would be great to be able to 3D print an encoder to go with it (as a cool "making something yourself" experience for the students.) I'm not sure where or how you'd find a gear like this though.
Thanks everyone!
Unread 20-01-2017, 00:13
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: VersaPlanetary Integrated Encoder question
Thanks everyone!
You do understand it correctly.
I would not recommend 3d printing an integrated VP encoder but you could certainly 3d print some other way to interface to them. If you do buy one then don't forget the lubrication.
EDIT: Based on Paul's comments below.
Unread 20-01-2017, 07:35
President, VEX Robotics, Inc.
The VP encoder uses the exact same encoder board that the CTRE mag encoder uses. VEX purchases the fully tested board (not just IC) from CTRE and integrates it into a VP slice.
The gear is a custom gear we designed and manufacture specifically to interface with the "spline gear" that couples each of the ring gear stages together. You have to purchase the entire encoder slice in order to get this gear. The gear would be very hard to integrate into a custom gearbox because it is a specialized metric gear with profile shift in order to get the gear ratio and packaging we wanted. And yes, the gear has the magnet already embedded. We wanted to make it as easy as possible to use.
Now, one thing you can do is make a VP with no gear stages, just the input->encoder slice ->output and use that to connect to your spinning shaft. I know it may be a little heavier than you want, but it is very fast to integrate.
Otherwise, I would just use the mag encoder with a magnet you embed in a shaft.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 20-01-2017, 09:51
trycatch's Avatar
FRC #5858
Rookie Year: 2015
Cool, thanks for the input. I'm definitely not trying to avoid buying VersaPlanetary's, I was just trying go figure out how to put the CTRE mag encoders that we have to use in a similar fashion (i.e., without having to embed a magnet.) Thanks all!
Unread 20-01-2017, 11:47
Anytime! We will put the ability to purchase the hardware without the encoder on our list for next season's potential additions to the product lineup.
Unread 20-01-2017, 12:13
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
5406 designed a 3D printed insert to use the encoder mounted directly to a hex shaft. I haven't actually made one so I can't comment on it's success. Maybe someone from CeltX can talk about how it worked for them.
http://www.thingiverse.com/thing:1473056
2016: TVR #2 seed + Finalist | FLR #1 seed + Semifinalist | Hopper Finalist | IRI Semifinalist
2015: TVR Finalist | FLR #1 seed + Finalist | Carson Quarterfinalist | IRI Quarterfinalist | Ruckus Winner
Unread 20-01-2017, 21:39
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Originally Posted by Maximillian View Post
5406 designed a 3D printed insert to use the encoder mounted directly to a hex shaft. I haven't actually made one so I can't comment on it's success. Maybe someone from CeltX can talk about how it worked for them. http://www.thingiverse.com/thing:1473056
It worked great! We used then for the drive encoders, as well as our winch. This year we plan to do the same thing for our drive encoders, although we're going to try to print our own housing too that's better suited to be mounted to a WCD style live axle.
