Go to Post dang. I wish my legs were as good as Dave's. - Amanda Morrison [more]
Unread 19-01-2017, 22:45
qscgy's Avatar
qscgy qscgy is offline
The Last Airbender of 449
AKA: Sam
FRC #0449 (Blair Robot Project)
qscgy will become famous soon enoughqscgy will become famous soon enough
Team 449 Climber
This is the climber prototype built by Team 449, the Blair Robot Project. We weren't sure how legal it was to use Velcro, so we build what I've been calling macro-Velcro: spinning "hooks" (actually just bolts) that grab a loop. There's also a slipknot that allows the rope to wrap around the winch reel a couple times before it starts bearing a load. We complete the climb in about 6 seconds. Questions/suggestions are welcome!
Video
CAD:
Unread 19-01-2017, 22:48
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Re: Team 449 Climber
Looks sick. What gear reduction are you using?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 19-01-2017, 22:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You have plans for something to trigger the touchpad before you run into the channel? You'd probably hit the touchpad first tilted sideways like that, but you might not if you went up especially balanced.
Unread 19-01-2017, 22:52
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
Far from impossible. Just add some 2" sticks extending straight up (or whatever direction you're climbing).
Unread 19-01-2017, 22:53
qscgy's Avatar
AKA: Sam
50:1 on a VersaPlanetary attached to a Mini CIM.
Unread 19-01-2017, 23:00
qscgy's Avatar
AKA: Sam
Not yet. Ollien's suggestion of sticks could work, as could a pneumatically-actuated bar of some sort. Thanks for telling us this!
Unread 19-01-2017, 23:13
Nothing's impossible or even very difficult at this stage. It gets tough when you show up at your first competition with a climber at the very top of your robot volume, though. I think there's a lot of people forgetting that the challenge isn't climbing, it's pressing the touchpad for >1s.
Unread 19-01-2017, 23:47
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
How much weight was that in the video? Looks like a cool design! (At least, it's not velcro anyway )
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 20-01-2017, 00:20
qscgy's Avatar
AKA: Sam
It probably weighed about 40 pounds, although we designed it to lift 150. It's the frame (made of 80/20) from our 2010 robot, with a battery and electronics board attached.
Unread 20-01-2017, 00:21
OMGRobots1's Avatar
OMGRobots1 OMGRobots1 is offline
AKA: Robby Shield
FRC #5026 (Iron Panthers)
OMGRobots1 is on a distinguished road
Very impressive. What power was the motor running at?
Unread 20-01-2017, 00:37
qscgy's Avatar
AKA: Sam
Full power.
Unread 20-01-2017, 00:49
jojoguy10's Avatar
AKA: Joe Kelly
I'd be very interested to know how it performs at about 150lbs (maximum robot weight is 154lbs)
Unread 20-01-2017, 01:13
Oblarg Oblarg is offline
AKA: Eli Barnett
The gearing was selected very conservatively to ensure that we're on the rising side of the power output curve.
The current gearbox is 50:1. Mini-CIM output torque is listed at 1.4 N*m. Our winch drum is 1.25'' diameter, so .625'' radius.
Neglecting friction, we have:
(150 lbs * .625'')/(1.4 N*m * 50) = ~15% of stall torque.
Now, I have really no idea how big the frictional losses actually are in this system, but I don't think there's any way they'll take us from 15% motor loading to over 50% (which is peak power, i.e. the loading for which this gearing provides optimal climb rate).
Fully-loaded climb rate (using the frictionless numbers) is somewhere around 6'' per second.
Upon reflection, we could probably gear it a bit faster (we had done the math for the gearbox when we were considering a larger-diameter winch).
"The breakfast of champions!"
Unread 20-01-2017, 01:24
T^2 T^2 is offline
FRC #5499
Your gearbox will fail you after a regional's worth of matches, maybe sooner. The aluminum ring gear will flex enough to allow the planet gears to ratchet, and you will lose the climb.
Unread 20-01-2017, 01:40
AKA: Eli Barnett
Are you sure? The 50:1/mini-CIM combo is labeled as acceptable by VexPro's documentation, and as noted above we're not actually anywhere near the peak loading on it.
