Re: Team 449 Climber
Catapult failure in first 2014 regional, canburglar failure in second 2015 regional. Similar physical setups.
Any gearbox suggestions, then?
Maybe custom if you have resources. Vexpro CIM gearboxes would work, but bulky because you'd need two reductions.
I think I'd rather try to add a 2:1 reduction or similar via. chain to reduce torque on the gearbox if this proves to be problematic. |
Are you sure you were using the VersaPlanetaries correctly? I've used them a number of times without problems and I've pretty much only heard good things about them. Were you properly greasing them? Did you check the max loading guide before choosing a reduction? Did you assemble them in highest to lowest reduction order? Did you support the end of the shaft?
