Go to Post FIRST teams procrastinate and slack off?!?!? The question is, if you do it in a way that keeps your grandmother proud, would that make it "Gracious Procrastinatism?" - Mr MOE [more]
Unread 20-01-2017, 01:44
T^2 T^2 is offline
FRC #5499
Re: Team 449 Climber
Originally Posted by Oblarg View Post
Are you sure? The 50:1/mini-CIM combo is labeled as acceptable by VexPro's documentation, and as noted above we're not actually anywhere near the peak loading on it.
Catapult failure in first 2014 regional, canburglar failure in second 2015 regional. Similar physical setups.
Unread 20-01-2017, 01:48
Oblarg Oblarg is offline
AKA: Eli Barnett
Any gearbox suggestions, then?
"The breakfast of champions!"
Unread 20-01-2017, 01:55
T^2 T^2 is offline
FRC #5499
Maybe custom if you have resources. Vexpro CIM gearboxes would work, but bulky because you'd need two reductions.
Unread 20-01-2017, 02:01
AKA: Eli Barnett
We don't have much in the way of machining resources at all (miter saw, drill press, and a little hobby lathe), and the drive gearboxes would be an absolute nightmare in terms of space/weight.
I think I'd rather try to add a 2:1 reduction or similar via. chain to reduce torque on the gearbox if this proves to be problematic.
Unread 20-01-2017, 05:26
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Are you sure you were using the VersaPlanetaries correctly? I've used them a number of times without problems and I've pretty much only heard good things about them. Were you properly greasing them? Did you check the max loading guide before choosing a reduction? Did you assemble them in highest to lowest reduction order? Did you support the end of the shaft?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 20-01-2017, 07:27
President, VEX Robotics, Inc.
Your gearbox will fail you after a regional's worth of matches, maybe sooner. The aluminum ring gear will flex enough to allow the planet gears to ratchet, and you will lose the climb.
Bold words are mine for emphasis.
This is completely false. This is not how the ring gear works in a planetary system. The only load that goes in the direction to cause the gear to flex is the separation forces of the planets, which is quite low even when the gearbox is overloaded. Please do not make claims that look like statements of fact when you have no idea what is actually going on.
Now, I am sorry that you had failures, but I can tell you that a steady climb is NOTHING like catapult and can burglar loading scenarios as those have extremely high shock loads. I an willing to bet that you either had planet carrier failure or a failure of the spline. I would like to hear about the details of your setup and I can pinpoint exactly what failed and why.
We did excessive failure testing on the VersaPlanetary and failed it in ways you can't even imagine. That is how we developed the load rating table and that is why the 10:1 has lower load rating due to the nature of the failures.
Again, I would love to help pinpoint what happened on your can burglar and catapult, but my team used VPs for both applications with exactly 0 failures.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 20-01-2017, 08:18
lphung lphung is offline
FRC #5994
lphung is an unknown quantity at this point
Nice design. Just a quick question/comment: Is the geartrain's resistance enough to prevent the robot from releasing the rope if the battery runs out of juice? I would consider the event in which your system reaches the top of the rope and needs to maintain its height until the end of the match.
Unread 20-01-2017, 08:57
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Please explain.
This application is within the load ratings of the VP gearbox for this application. I have a hard time believing that they'll have a problem considering how many VP gearboxes my team has run at the edge of what they're rated for (and sometimes past). Suffice it to say the VPs have taken every ounce of use and abuse we could throw at them and still work great.
Unread 20-01-2017, 10:56
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
Can't wait for district competition event and hopefully will be on the same alliance this year. Good Luck 449 and Wil see you soon on the field soon
FRC Events:
Chesapeake Regional Rookie inspiration award 2009
Offseason Event:
Battle O'BAltimore Champions 2010
FRC Teams :
2849 Ursa Major (Student 2009-2011) (Mentor2011- Current)
5979 (Mentor 2015-Current)
Unread 20-01-2017, 11:13
AKA: Eli Barnett
We have a ratcheting wrench on the hex shaft that the winch drum is attached to.
Unread 20-01-2017, 11:30
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Also, what gear boxes are suggested for the climber reduction??
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 20-01-2017, 11:50
AKA: Eli Barnett
There's been a rather extensive discussion of this already in this thread!
We're currently using a versaplanetary with a 50:1 reduction, though we may reduce it to 40:1 or 30:1 pending further testing with a full-weight robot. I would not advise just blindly copying this without understanding the motivation for this choice, however - if you go back to the first page, I posted the math behind it.
Unread 20-01-2017, 12:20
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
We have used VP for years and only ever had 3 fail. But the 2 that had gears fail were back in 2014. I cant remember the ratio, but we had the two gears that goes in the center separate, because they were only pressed together. (We also did not do much looking into the loading charts or anything like that back then) In 2015 we had a pin fall out of one of the gear ratios inside the gearbox. The pin then jammed up the gearbox and burnt up the motor mid match. I would put all my money on the VP gearboxes. IMO they are the greatest cots gearbox available. (Excludes drivetrain)
Unread 20-01-2017, 13:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I can say from experience that VPs don't deal well with an axial load pulling on the shaft. They seem fine with a moderate axial load pushing on the shaft. I've failed them two ways pulling on the shaft. In 2014, we had a ridiculous arm intake mechanism lifting a bunch of mecanums on a long lever arm. It was actuated by a leadscrew attached to a VP. The weight on the arm was failing the shaft retaining ring by deforming the groove. My only option for fixing that was making a bearing block for the leadscrew with a flange nut transmitting the tension to the bearings. Thus sparing the VP.
Second was in 2015, leadscrews moving our stacking mechanism up and down. Except programming decided to up limits switches right next to hard stops, so when we lowered the lift, it hit hardstops, pulling the leadscrews up and over several cycles pulling the 8mm CIM shaft out of the VPs. I had thought it was solid, but no, it's pressed in. Solved that one by machining down a 1/2 hex shaft to 8mm, and fixing the program to PID to position like it was supposed to.
TLDR; don't pull on the VP shafts. They're not really designed to put up with that.
Unread 20-01-2017, 17:09
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Wait - there is a knot in the at the bottom end of the rope? Or, Are you planning to bring your own rope and its legal to have a knot at the bottom to grab onto?
Brian K
Team 1225 Robotics Mentor
