Re: Multiple Vision Targets using GRIP
The findContours method used by GRIP should generate a list of contours (MatOfPoint), and it shouldn't be limited to just one contour. I'm not too familiar with grip generated code, but you should be able to modify it if needed to either get the full list of contours or get the first and second contours.
Our team has an example based off of grip's generated code that allows getting the full list of contours here. You can tune that to accept both contours. |
System.out.print({Class}.getContours()); but that ended up printing out nonsense: https://postimg.org/image/nboabyidr/ Thanks, |
I believe I have found the solution. I ended up modifying the code here:
https://wpilib.screenstepslive.com/s...-robot-program I duplicated the statement that defines rectangle 'r', changed the second one to 'q', then changed the '0' in 'filterContoursOutput().get(0)' to a '1'. I also changed centerX to two different variables, one for rectangle r and one for rectangle q. My problem now is that sometimes, when running the robot, the values from the contours just suddenly stop, and will not update until I redeploy. I believe that for some reason, the visionThread is being stopped. If I try to use visionThread.start() somewhere in the program (besides robotInit), the program crashes (we suddenly lose robot code and comms in the driverstation). Anyone have an idea how I can resolve this issue? |
