Go to Post Let gravity be your friend. - MrForbes [more]
Unread 20-01-2017, 10:31
ckpash88 ckpash88 is offline
FRC #5637
ckpash88 is an unknown quantity at this point
2 cim vs 1 cim
I cant seem to find the answer to this question.
Do you believe we can get away with using 1 cim motor per tough box mini. We plan on making a light robot and we think that taking two motors out would save on weight. Our thoughts is that we aren't going over any obstacles so we should be able to get away with it.
Do you agree?
Thanks,
Team 5637
Unread 20-01-2017, 10:37
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: 2 cim vs 1 cim
Do you agree?
Thanks,
Team 5637
Assuming you mean to use these toughbox mini's on your drivetrain, use 2 per toughbox. In my rookie year, we used 2 cims to power our drivetrain and we quickly added 2 more when we got to the competition. It's worth putting power into your drivetrain, and having weight down low is never a bad thing.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 20-01-2017, 10:38
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: 2 cim vs 1 cim
The top of my head answer is no. Yes the robot will move with 1 cim per side. Unless you gear down or use omni wheels on one end, it will not turn from a stand still very well. You will have issues playing defense or with defense.
Unread 20-01-2017, 10:44
foote stepped in
AKA: E. Foote
FRC #0868
Re: 2 cim vs 1 cim
Do you agree?
Thanks,
Team 5637
The amount of weight saved is negligible compared to the amount of power you'd be taking out of your drive train. I'd recommend that you keep the motor.
Take a look at Ether's drivetrain acceleration model, and compare your results between a 2 cim vs 4 cim (+6 lbs) robot.
https://www.chiefdelphi.com/media/papers/2868?
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 20-01-2017, 10:50
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: 2 cim vs 1 cim
I vaguely remember thinking this would be a wise decision in one of my team's early competitions. It was not wise. You will lose significant acceleration, and everyone else on the field will outrun you. More importantly, the teams chasing you will catch you and push you, and they will win the pushing matches. You will regret the choice, unless your team goals do not include being competitive.
http://www.angelbotics.com
Remember why you're doing this.
Unread 20-01-2017, 10:54
FRC #5637
Re: 2 cim vs 1 cim
Sounds like we will being going with 4 motors. Thanks for the quick responses
Unread 20-01-2017, 10:57
mrnoble's Avatar
teacher/coach
Re: 2 cim vs 1 cim
Best of luck. You will not regret this decision.
Unread 20-01-2017, 10:59
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
Re: 2 cim vs 1 cim
I'm not sure if this is exactly what you are looking for but this is a paper our team did at the end of 2014. It is comparing 2 CIMs (1 per side), 4 CIMs (2 per side), 4 CIMS + 2 Mini CIMS (2 CIMS and 1 mini CIM per side), and 6 CIMs (3 per side). I think it's worth checking out for drive train decisions, even if it's not exactly what you're looking for.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 20-01-2017, 11:45
FRC #1836 (MilkenKnights)
Re: 2 cim vs 1 cim
If your robot is light, the weight of 2 extra CIMs shouldn't be an issue.
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
Re: 2 cim vs 1 cim
Interesting. Any guess how 6 mini-CIMs would perform?
Unread 20-01-2017, 11:54
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: 2 cim vs 1 cim
Do you agree?
Thanks,
Team 5637
Never, ever make a drive with only one CIM per side.
Your acceleration will be bad, and you will trip the 40 amp drive breakers repeatedly as you inevitably stall your motors.
"The breakfast of champions!"
Unread 20-01-2017, 12:04
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
cj3958 will become famous soon enough
Re: 2 cim vs 1 cim
Yes you could theoretically do this. It is probably not a good idea for several reasons. The first is that you probably don't need to save weight. This year especially, unless you have 12 moving actuators and you make everything out of steel you probably won't be too close to the 120 lb limit. If you want to just be lighter so you accelerate faster, removing the motor is not the way to go. Drive train motors put more energy into moving than they take out, so removing them will not help you accelerate faster. If you really need to weight savings, I would recommend using 2-3 775pro's per side. They have approximately the same power output, but they are a lot lighter. The downside is that they COULD overheat, but they probably wont. You can use a CIM-ile from vexpro as your first stage, and from there it will fit right on to the toughbox. I would only do that once you find out you need the weight though.
TL;DR
You can, but you shouldn't(most likely). Better option would be to use 775pro's, but the best option is to simply use more CIMs.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 20-01-2017, 12:13
RoboChair's Avatar
AKA: Devin Castellucci
Re: 2 cim vs 1 cim
Originally Posted by cj3958 View Post
TL;DR
Please don't put 775pros in the drivetrain unless you REALLY know what you are doing with them. I have in my 12 years of FRC only heard of 1 CIM in a drivetrain that got smoked. CIMs are the closest I have seen to indestructible motors that you can buy, they just won't die.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 20-01-2017, 12:36
foote stepped in
AKA: E. Foote
FRC #0868
Re: 2 cim vs 1 cim
In a drivetrain, a 775pro WILL overheat.
Stall them for more than 3 seconds, and they're no longer motors. Run them for more than 90 seconds at peak power, and they're no longer motors.
See actual test results here: http://motors.vex.com/775pro
Unread 20-01-2017, 12:39
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: 2 cim vs 1 cim
It was absolutely okay in 2009.
