Go to Post In my opinion, I wouldnt want gifts or praise from people about my help to a robotics team, all I would want is a thank you, that would make all my hard work and efforts worth while and it would prove to me that I could actually be making a difference in the students lives - Mike Schroeder [more]
Unread 17-01-2017, 08:50
swolverines's Avatar
swolverines swolverines is offline
FRC #3839
swolverines is an unknown quantity at this point
Question Struggling with LabView and Talon SRX CAN
No one on my team is very versed with LabView. I have just been recycling the same code year after year. Unfortunately? I am unable to do that this year, as we are planning to use CAN motor controllers. We got them all updated and programmed yesterday so they have their own ID numbers. I can't for the life of me figure out how to program them though. We used to just pick an Open 4 Motor and assign the PWMs and boom, we were done. I just can't figure this out. ANY help is appreciated. I read the Software Reference Manual for the Talon SRX, installed the special vi's, but it doesn't make any sense to me.
Thanks in advance.
Unread 17-01-2017, 09:08
Billfred's Avatar
Billfred Billfred is online now
Re: Struggling with LabView and Talon SRX CAN
Thanks in advance.
1) You should really read the rules in the manual as they pertain to software development before Kickoff. (I don't know for sure if you'd be violating them, but it's possible.)
2) As was announced months ago on the FRC blog, third-party device code is out of WPILib starting this year. Read this: http://wpilib.screenstepslive.com/s/...-talon-srx-can
Unread 17-01-2017, 10:29
FRC #3839
1) By recycling I mean rebuilding. It's pretty simple code to re-write. We create a fresh version of the code every year.
2) I saw that, I installed the stuff that gave me the vi's pertaining to the Talon, but I don't know what to do with them, which is where the problem lies.
Unread 17-01-2017, 11:27
Hess1113's Avatar
Hess1113 Hess1113 is offline
AKA: Christopher Hess
FRC #0291 (CIA)
Rookie Year: 2017
Hess1113 is an unknown quantity at this point
Smile Re: Struggling with LabView and Talon SRX CAN
Our team did the same thing and we switch over to CAN Talon SRX. I found that you had to mix the Motors controllers and specially VI's. I also found code examples by searching in google images "CAN Talon SRX Example Code". If you need any help I am also available via skype or email. Just direct message me. Also Github has examples.
Happy building
Unread 17-01-2017, 21:24
zvankirk zvankirk is offline
FRC #3991 (KnightVision)
Rookie Year: 2015
zvankirk is an unknown quantity at this point
First, download the toolsuite. The CAN SubVIs are not included in this year's labview distribution.
http://www.ctr-electronics.com/downl...20v4.4.1.9.zip
Install, then download the FRC examples -- use these for some guidance.
https://github.com/CrossTheRoadElec
The basic programming of the Talon SRX is the same as the old Talon, but the SRX can do much much more! Have Fun!
Unread 19-01-2017, 12:26
GrizBear GrizBear is offline
AKA: Mason
FRC #4296 (Trident Robotics)
Rookie Year: 2016
GrizBear is an unknown quantity at this point
Thanks in advance.
I had this struggle because I wanted to open four motors for the mecanum drive. This is what worked for me:
Download the CTR SRX libraries.
Modify the open 4motor vi by replacing the open motors, with the open motors from the srx palette. Replace variable accordingly.
If you have any questions on the exact process, let me know, I'd love to help.
Unread 19-01-2017, 13:01
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of light
You should not have to modify any existing sub-VIs to have CAN Talon SRX work with the Open 2/4 Motor VIs. In fact, I would definitely recommend not doing these modifications unless you are extremely proficient in LabVIEW.
To use CAN Talon SRX with these multi-motor Open VIs, wire the output of the Talon SRX Open VI to the input of the Open 2/4 Motor VI when "Existing Motors" is selected from the drop-down. There is an example of this in our LabVIEW Simple Arcade Drive Example on GitHub.
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
Unread 20-01-2017, 10:44
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
For those who don't want to go digging around in GitHub, here's a screenshot of what this should look like.
The numbers (1,2,3,4) correspond to the Device IDs you gave the Talons when you set them up on the Rio's configuration page.
You may have to change which motors are inverted based on your robot's setup.
Name:	Drive - Open 4 Talon SRX.PNG
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 26-01-2017, 14:58
fizxtchr fizxtchr is offline
Cass Tech Nerd Master
AKA: Karl Balke
FRC #2673 (Tenacious Technicians)
fizxtchr is an unknown quantity at this point
Thank you for the diagram. My programmers took one look and left smiling!
