Go to Post our electronics boards had begun to look like we'd planted a wire bush and it grew - daltore [more]
Unread 20-01-2017, 10:47
trycatch's Avatar
trycatch trycatch is offline
FRC #5858
Rookie Year: 2015
trycatch is on a distinguished road
Mounting AMT10s to CIMs + gearboxes?
Sorry for what's probably a really obvious question, but I'm trying to work out how you mount AMT10s (or similar encoder) to a CIM and a gearbox... the output shaft of our gearboxes are larger than the AMT10 sleeves will accommodate (1/2" or 3/8"). Should it maybe be mounted on a parallel axle being turned by the output shaft?
Unread 20-01-2017, 11:14
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Mounting AMT10s to CIMs + gearboxes?
I'm not sure what you mean by mounting the encoder to a CIM and a gearbox. If they are mechanically linked, you only need an encoder on one of them.
Are these custom gearboxes or COTS gearboxes? If they're COTS, most COTS gearboxes have a built-in encoder mounting point. If it's a custom gearbox, maybe you can turn down the other end of the output shaft and mount the encoder on the back, like in the Toughbox series of gearboxes from AndyMark.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 20-01-2017, 11:23
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Try this.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 20-01-2017, 11:24
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Originally Posted by Munchskull View Post
I love that design. We used one a couple years back for testing and ended up going with these encoders on our 2015 robot because of it. We didn't mount them like this but it's a cool design.
Unread 20-01-2017, 11:30
Munchskull's Avatar
Team Role: CAD
Thank you, it took quite a few tries to get right. Becomes a little confusing for others when talking about it since another encoder solution came out months later under the name.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 20-01-2017, 11:31
trycatch's Avatar
FRC #5858
Rookie Year: 2015
Oooooh, that's *awesome*.
In response to the other questions, I was trying to figure out how you could mount the encoder to the CIM, and then the gearbox onto that, since the AMT10 just barely accepts the CIM output, and won't accept a 3/8" or 1/2" shaft, so putting the AMT10 onto the output of the gearbox wasn't an option.
This custom part here is a great solution!
Unread 20-01-2017, 11:38
Munchskull's Avatar
Team Role: CAD
PM me any question about how to implement this properly.
Anthony Cardinali
4th year of FRC
Class of 2017
