Go to Post If only more people could have the same attitude toward FIRST as they do toward their fellow teams! - Jaine Perotti [more]
Unread 20-01-2017, 12:25
ethan271's Avatar
ethan271 ethan271 is offline
FRC #0935 (Railerobotics)
Rookie Year: 2015
ethan271 is an unknown quantity at this point
Limit full power on victor sp
So we saw with a test robot that our drive is too fast, is there a way that we could limit the victor to were if we were full on the joystick that it would max out power to 75%? We are using labview for programming.
01010111011010010111001101101000001000000111010101 11001100100000011011000111010101100011011010110010 0001
Unread 20-01-2017, 12:28
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Limit full power on victor sp
I don't know labview, but you should be able to just multiply the joystick input by some constant less than 1.
"The breakfast of champions!"
Unread 20-01-2017, 12:35
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
arichman1257 will become famous soon enougharichman1257 will become famous soon enough
Do this ^^. I do not know how to do it in LabView but it should be a similar method to any other language.
For example, for 75% multiply the value (between -1 and 1) from the stick by 0.75 (called a scale factor). And you will want to do that in whatever function/method you are using to send signals to the motor controller. In C++ (and Java, I think) you would do
Motor_Controller_Name.Set(Joystick_Input * Scale_Factor)
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator. MAR District Championship Winner, MAR Mt. Olive Event Winner, MAR Bridgewater-Raritan Event Finalist
2015: Control Systems, Operator. MAR North Brunswick Event Finalist
2014: Programming/Electronics Apprentice. MAR Clifton Event Winner
Unread 20-01-2017, 12:46
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
You can never have a robot that is too fast!
We usually use one of the joystick triggers to reduce the max speed by a software scale factor applied to the y-axis when we want finer control of the throttle.
If you want a permanent reduction it could be done mechanically with gears. sprockets or smaller wheel. This will let you use the full power of the motors.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 20-01-2017, 13:00
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
This. If your drive system is faster than you ever intend to use, get a lower gear ratio. Otherwise you're wasting power and efficiency in your drive.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 20-01-2017, 13:03
AKA: Alan Richman
Even though this is harder than the code thing, this is a better solution.
Unread 20-01-2017, 13:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The question is, in what way is your drivetrain "too fast"?
Is the top speed more than your driver can handle/control? If so, either more drive practice, or gear lower as suggested above so that you will use less current accelerating and/or accelerate to top speed faster.
Is the acceleration (particularly at low speed) too great, causing you to fall over backward? If so, less grippy wheels or voltage ramping (programming so that you are only increasing the voltage at a maximum rate, e.g. 20% throttle per 100ms) may be the answer.
If the joystick is too sensitive in "parking" maneuvers (e.g. lining up to get or score game pieces), you could have a switch to go between two throttle modes, or program a nonlinear response to the joysticks. Ether's paper on joystick sensitivity is a great resource for the last.
Edit: I've never written any LabView, so forgive me if my terms are way out of whack, but if you really still want to do what you asked at the beginning, you would add two "multiply" operators. Break the wire connecting your joysticks (or arcade operator) to your motor controllers. Feed the joystick output to one input, 0.75 to the other, and the output goes to the motor controller input.
That throttle switch idea would give 1.0 at one throttle setting and (for example) 0.5 at the other where I had 0.75 above.
