Go to Post I found the best way to slice through pit crowds is to carry a clipboard and look like you know where you are going. People just seem to slide out of your way. :) - Ian Curtis [more]
Unread 20-01-2017, 14:23
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
2017 Team Update 4
https://firstfrc.blob.core.windows.n...amUpdate04.pdf
Major updates:
  • Details regarding Early Pit Setup
  • Added images depicting the Davit position when the Touchpad is unactuated and fully actuated
  • Ranking Score will be truncated to 2 decimal places.
  • For Playoffs, Alliance Captain is assigned Player Station 2, with the first pick now being assigned the Player Station closest to the Boiler and the second pick now being assigned the Player station closest to the opponent's Loading Station.
  • Added District Chairman's, Dean's List, Engineering Inspiration, and Rookie All-Star Award allocations.
Unread 20-01-2017, 14:26
rcoren22's Avatar
rcoren22 rcoren22 is offline
FRC #0223 (Xtreme Heat)
rcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to behold
Re: 2017 Team Update 4
Thanks Ryan!
The illiterate of the future will not be the person who cannot read. It will be the person who does not know how to learn.
Alvin Toffler
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
ALLIANCE Leads are assigned to PLAYER STATION 2, the first picks are assigned to the PLAYER STATIONS closer to the BOILER, and second picks are assigned to the PLAYER STATIONS closer to the opponent’s LOADING STATION.
Woo!
GitHub
Unread 20-01-2017, 14:30
GuyM142's Avatar
GuyM142 GuyM142 is online now
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
ALLIANCE Leads are assigned to PLAYER STATION 2, the first picks are assigned to the PLAYER STATIONS 1 closer to the BOILER, and second picks are assigned to the PLAYER STATIONS 3 closer to the opponent’s LOADING STATION.
2nd picks are going to have a hard time trying to defend the opponents boiler, the drivers won't see anything from their station!
Also, 1st pick won't be able to see the loading station well.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 20-01-2017, 14:33
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
The fact that there's a steel piece that extends past the touch plate so you can't actually use your climber to touch the plate would have been good information to have a week ago. Glad we know now but how many teams will find themselves up and not climbed?
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 20-01-2017, 14:45
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Try to find a way to surround your climber with >0.5" foam to depress the touchpad.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 20-01-2017, 14:47
Rat_nanny Rat_nanny is offline
Rat_nanny is an unknown quantity at this point
This has been a discussion for the past week. It's why I am glad I follow this and a few other forums.
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
On the other hand, this setup will likely reduce the number of mangled touchpads, and makes it easier to apply a 3-5 pound force to the touchpad while you're pulling on the rope with 100+ pounds of force.
But yes, it's going to be rough for teams whose winch or chock is right at the top of their allowable volume.
Unread 20-01-2017, 15:04
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
But... 3.25" of bumpers stick out of the winch basically* no matter what. I don't think this was a large problem to start with.
*Assuming you don't actuate your winch out over the bumper and also the winch is situated a tad higher than your bumpers.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 20-01-2017, 15:15
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
**Assuming that you need to articulate your robot 90 degrees to climb.
Unread 20-01-2017, 15:18
Roboter
Rookie Year: 2015
Only if the vertical line through the robot's COG and winch also passes through the bumper. In which case, the simple solution is to make a cut in the bumpers.
Unread 20-01-2017, 15:19
Chris is me's Avatar
AKA: Pinecone
This was an issue since Day 1; I'm glad as soon as FIRST realized how this impacts designs (and how it wasn't in the team drawings...) that they added visibility to the issue in the manual in order to help teams. Should have been sooner, but I'm glad it's happened
As for playoff player station assignments, this system seems okay. I do wish you were allowed to choose which player station you could go to, but I understand why that isn't done, and as long as that isn't a thing, this is the best we've got.
Unread 20-01-2017, 15:20
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
I envision that there are many teams out there whose bumpers won't come into play during climbing at all.
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Which isn't allowed.
Unread 20-01-2017, 15:21
AKA: Pinecone
You're totally allowed to have gaps in the bumpers this year. This is how I imagine the vast majority of teams will be acquiring game pieces from the floor this year.
