Go to Post No really though, a robot game with rules similar to Risk. This would combine FIRST, Battlebots, and US Government... - Betty_Krocker [more]
Unread 20-01-2017, 15:24
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Bumper Thickness
Is there any official rule on the thickness of the bumper. I have seen bumpers anywhere from 3.5 inches thick to 2.5. This year it would be nice to have a hard rule on it
2016 Tesla Division Finalist
2016 Central Illinois Regional Finalist
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 20-01-2017, 15:26
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: Bumper Thickness
Rule R29.
Unread 20-01-2017, 15:29
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
R29 A. "be backed by 3⁄4 in. (nominal) thick (~19mm) by 5 in. ± 1⁄2 in. (~127 mm ± 12 mm) tall plywood or solid, robust wood."
R29 C. "use a stacked pair of approximately 21⁄2 in. (nominal) round, petal, or hex “pool noodles” (solid or hollow) as the BUMPER cushion material"
#StaySavage
Unread 20-01-2017, 15:37
Bpk9p4's Avatar
FRC #1756
however it goes on to say this "Noodle compression as a result of smoothing BUMPER fabric is not
considered deformed. Any compression beyond that, e.g. for the
purposes of flattening the noodle, is deformation and a violation of R29-" so how much of that is ok?
In the past are bumpers have always been around 3 inches thick including playwood and mounting brackets. Is that ok?
Unread 20-01-2017, 16:18
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
It's really impossible to give a strict number, as pool noodle manufacture doesn't hold to very strict diameters. That said, there is a noticeable difference when holding a bumper that has been properly constructed, versus one that was constructed with the intent of flattening the pool noodles.
Go ahead an pull the fabric tight. But don't staple your fabric on while you have someone sitting on the bumper, that will flatten the pool noodles and not provide sufficient space for them to expand back out to their proper size.
2016: Lake Superior WFFA
Unread 20-01-2017, 16:22
Chris is me's Avatar
AKA: Pinecone
I generally assume bumpers are 3.25 inches, with whatever slight compression is placed on the pool noodles offset by the thickness of the fabric. For frame perimeter calculations this year, I'm treating bumpers as 3.5 inches thick, in order to build 1/2" undersize in each dimension.
Compressing bumpers to get within the size volumes is going to be even more frowned upon / illegal than it already was.
Unread 20-01-2017, 16:40
Mentor, LRI, MN RPC
These are good assumptions to make if you want to pass inspection!
