Go to Post When Dean says it's not about the robot he really means it. We're gonna get a speech whether we want it or not and of we complain we'll get even more. - Koko Ed [more]
Unread 20-01-2017, 15:39
SVV-AJ SVV-AJ is offline
FRC #6519
SVV-AJ is an unknown quantity at this point
Smile 2017 test board code
Our team is new and we don't know coding yet. We just finished building a basic programming board. Does anyone know where to find some premade java code for the roboRIO? Any general programming tips would be appreciated. Thank you!
Unread 20-01-2017, 16:00
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
Re: 2017 test board code
Checkout the youtube series on RobotBuilder: https://www.youtube.com/watch?v=k7Pa...lgn vhGObeKzp
and the screen steps https://wpilib.screenstepslive.com/s/4485/m/26402
You can also find a fair amount of code by looking around here and github.
Good luck
Unread 20-01-2017, 17:09
FRC #6519
Thank you very much for the help! where can you go to download robotbuilder?
Unread 20-01-2017, 17:11
MJS103's Avatar
MJS103 MJS103 is offline
FRC #6519
MJS103 is an unknown quantity at this point
Bump.
Unread 20-01-2017, 17:50
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
It will be installed when you set up your eclipse environment using the http://wpilib.screenstepslive.com/s/4485/m/13809 The Little red robot at the top of eclipse on the drop menu tool bar will launch Robotbuilder.
