Go to Post I'm not even going to bother...SEARCH! - sanddrag [more]
Unread 20-01-2017, 13:03
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
looking for flexible shaft coupler for 1/2 inch hex
Do any of you know where a person could get a flexible shaft coupler for high rpm and 1/2 inch hex shaft?
Or how one would make them without a CNC mill?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 20-01-2017, 13:05
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: looking for flexible shaft coupler for 1/2 inch hex
How much load does the coupler need to take? Is this an encoder coupling (i.e., basically no load) or are you looking to actually transfer motion within a mechanism?
If it's the former, your best bet is to turn the shaft down to 1/4'' round and use an ordinary helical beam coupling.
If the latter, you could possibly hex broach a spider coupling.
"The breakfast of champions!"
Unread 20-01-2017, 13:07
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
Why not use the surgical tubing coupler method?
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 20-01-2017, 13:10
AKA: Eli Barnett
We used to do this, but found last year that this is prone to introducing a fair bit of noise into the encoder readings. We never quite found out why, though my best guess is some sort of stick-slip effect.
It's not horrible if you use thick tubing and align the shafts well (it gets much, much worse with increasing axial misalignment), but the beam couplers have no such effect and are free from FIRST Choice so we use those now.
Unread 20-01-2017, 13:11
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
How flexible are we talking here? What kind of torque are you trying to transmit?
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 20-01-2017, 13:27
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Your chances of finding hex bore flexible shaft couplers are practically zero. But if you can round off the end of your hex shafts to 1/2" or a slightly smaller diameter, you can find flexible couplings.
Unread 20-01-2017, 14:17
Bruceb's Avatar
RS-775 pro direct driving 2 inch AM wheel for shooter through a VP planetary 1-1.
Unread 20-01-2017, 14:25
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
trying to drive a shooter, I wouldn't rely on a flexible coupler - a failure of that part would be pretty rough. I'd drive it through belts or gears instead.
2016: Lake Superior WFFA
Unread 20-01-2017, 14:26
AKA: Eli Barnett
I'd use a spider coupling for that. You can hex broach one, or else turn down the end of your shaft.
Unread 20-01-2017, 14:48
cbale2000's Avatar
AKA: Chris Bale
Why not just use a non-flexible coupler? Why does it need to flex?
The average flexible coupler is not really intended for these kinds of load transmissions. You might be able to get away with a universal joint but even that I wouldn't recommend for long term use because of durability and efficiency loss.
Unread 20-01-2017, 15:02
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
A 775 spinning at full boogie is up around 18,000 rpm ! A flex joint may not like the rpm if things aren't ballenced.
Unread 20-01-2017, 15:39
Bruceb's Avatar
I have a non flex coupler on there now it it vibrates a lot. That is why I was looking for a flex coupler of some kind. Maybe I will just cushion mount the VP and motor.
Will that vibration have an effect on the encoder?
Unread 20-01-2017, 15:43
Registered Muser
If vibration is your concern, a flexible coupler won't fix it. That's a product of the system design as a whole. You need to make sure everything is aligned properly, nothing's too out of balance, and all your motion is smooth and steady.
Unread 20-01-2017, 15:50
yarden.saa's Avatar
yarden.saa yarden.saa is online now
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
We had last year 775Pro on VP gearbox 3:1 direct drive a hex shaft with vex hex shaft coupler with no problem of vibrations. You are probably going too fast, I don't think you need 18000 rpm for a shooter.
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 20-01-2017, 16:09
cbale2000's Avatar
AKA: Chris Bale
If you're using a versa-planetary anyways, why not just use a versaplanetary encoder?
