Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 20-01-2017, 17:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: The Spring
Originally Posted by ahartnet View Post
Our McMaster one came in today. I took it over to the Robonauts so we could do a direct comparison between the century one they got with identical specs to the mcmaster one as far as I can tell (https://www.mcmaster.com/#9664k68 vs http://www.centuryspring.com/extensi...ings-e-41.html) They behave very differently.
Foreground picture is the century one, background one is the mcmaster. Heading over to FIRST Q&A now to ask if they're only going to source the spring from McMaster. Aw man, just missed being the cheesy poof question: https://frc-qa.firstinspires.org/qa/255
Have you tested the "initial load" "Minimum Load" of these, or the spring constants? Those would shed some light on the different behavior.
