Go to Post You can reduce the size of your wench. - ngreen [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #31   Spotlight this post!
Unread 20-01-2017, 16:10
CEF CEF is offline
FRC #5607
CEF is an unknown quantity at this point
Re: The Spring
Originally Posted by Justin Ridley View Post
We got our spring in as well. See link for video showing it is in fact "springy"
Seems like the pilots will need to be careful with how they lift the gears. A gear which is decidedly "on" the spring when the Pilot starts pulling could easily bounce off.
  #32   Spotlight this post!
Unread 20-01-2017, 17:20
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: The Spring
Originally Posted by ahartnet View Post
Our McMaster one came in today. I took it over to the Robonauts so we could do a direct comparison between the century one they got with identical specs to the mcmaster one as far as I can tell (https://www.mcmaster.com/#9664k68 vs http://www.centuryspring.com/extensi...ings-e-41.html) They behave very differently.
Foreground picture is the century one, background one is the mcmaster. Heading over to FIRST Q&A now to ask if they're only going to source the spring from McMaster. Aw man, just missed being the cheesy poof question: https://frc-qa.firstinspires.org/qa/255
Wow. That's really helpful to know. Though another thing to consider: While at the beginning of the season all the springs may behave like the McMaster spring, by the time champs rolls around, it may be an entirely different story. A Lift spring that has become damaged will hopefully be replaced. But a Lift spring that has become slightly stretched out and more likely to drop a Gear? We can be sure they'll still be in use.
  #33   Spotlight this post!
Unread 20-01-2017, 17:30
dardeshna's Avatar
dardeshna dardeshna is offline
Build Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is an unknown quantity at this point
Re: The Spring
We have a local spring manufacturer that offered to send us a couple for free... will post a video of our results when we get those to compare to century and mmc.
It looks like there are a few different ways to mount the spring (peg, something with screws, shaft collar?). Has anyone tested the shaft collar?
I remember reading that spring manufacturing tolerance is +/- 10% for the k value. Is there some math that determines how this affects the "bendiness" of a spring? How would one even measure the "bendiness" of a spring?
  #34   Spotlight this post!
Unread 20-01-2017, 17:34
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
The field drawing specifically calls out a 1/4" long rod (like 0.625 OD or something) that the spring very snugly fits over. The tour video shows a shaft collar not called out in the drawings. I asked about the shaft collar in my question on frc q&a
Sent from my SM-G930T using Tapatalk
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
  #35   Spotlight this post!
Unread 20-01-2017, 17:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: The Spring
Have you tested the "initial load" "Minimum Load" of these, or the spring constants? Those would shed some light on the different behavior.
  #36   Spotlight this post!
Unread 20-01-2017, 17:52
dardeshna's Avatar
Build Captain
AKA: Devin Ardeshna
Rookie Year: 2015
Re: The Spring
The initial load of the mmc spring is almost 25lbs, while the century spring is only 22lbs (according to sites). That might be a significant factor when combined with manufacturing tolerances.
Also the century spring seems to be carbon steel, while the mmc one is spring-tempered steel. Not sure what the difference is really though.
  #37   Spotlight this post!
Unread 22-01-2017, 18:26
bhughesa bhughesa is offline
bhughesa is an unknown quantity at this point
Gear peg spring stiffness
Our spring that came in was much less stiff than we had assumed. I am not sure how far off from the true spring it is (got it locally, very similar but not identical dimensions).
But, as a practical example, our gear falls off very easily if it is not put down at the very back of the spring. Anyone see this behavior as well? Anyone have the real McMaster part and have practical examples of how to get the gear on without slipping?
  #38   Spotlight this post!
Unread 22-01-2017, 18:32
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: Gear peg spring stiffness
https://www.chiefdelphi.com/forums/s...d.php?t=153835
#StaySavage
  #39   Spotlight this post!
Unread 22-01-2017, 18:51
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: The Spring
I've merged a couple of threads on this topic.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #40   Spotlight this post!
Unread 23-01-2017, 00:33
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: The Spring
Andymark has them in stock now.http://www.andymark.com/Spring-p/am-3557.htm
  #41   Spotlight this post!
Unread 23-01-2017, 01:01
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: The Spring
Does anyone know if these are sourced from McMaster or somewhere else? It seems springs with supposedly same specs are significantly different. Being AndyMark, they'll probably be the ones on the AM fields for districts, so hopefully it's the same source as FIRST.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
  #42   Spotlight this post!
Unread 23-01-2017, 01:04
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Recommending "Hidden Figures"
What I want to know is, if you drive into it and the tip of the spring hits one of the spokes of the gear, will it flex/deflect into one of the open spaces on the gear to allow for a successful hook or is it rigid enough that it acts like a solid dowel?
EDIT:
That merge really threw me off, I swear there was only one reply to the thread I posted in when I hit "Save".
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
  #43   Spotlight this post!
Unread 23-01-2017, 01:31
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: The Spring
Emphasis mine
Originally Posted by AndyMark Site, page linked above
Product Overview:
This is a steel compression spring, similar to the one used in the 2017 game FIRST STEAMWORKS℠.
  #44   Spotlight this post!
Unread 23-01-2017, 02:05
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
Re: The Spring
Emphasis mine
I'm sure that's simply to play CYA if the springs end up being different.
  #45   Spotlight this post!
Unread 23-01-2017, 05:42
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: The Spring
https://www.chiefdelphi.com/forums/s...6&postcount=53
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
