Go to Post If by hazardous you mean thinking about robots 24/7, waking up at 2am in the morning to jot some ideas down, completely losing your social life, and staring at a computer until your eyes hurt, then yeah! :D - looneylin [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 28-02-2012, 16:10
ProjectZero ProjectZero is offline
FRC #4276 (Vikings Robotics)
ProjectZero is an unknown quantity at this point
Help driving straight using PID and a Gyro.
Hi all,
Working on coding our robot to be able to drive straight using a gyroscope. The gyroscope initializes at the beginning of the map, getting it's initial heading. Now, I want the robot to at the press of a button be able to turn back to that orientation. I think I've finally structured the code below correctly. Questions:
1. Am I correct in assuming that when I enable PID in my DriveStraight command by writing enable(); that the robot will start doing what is written in the usePidOutput method?
2. What will the bounds of the "output" variable be? I know it's a finely tuned variable of the error between my gyro heading and my desired heading of 0, but I don't know if I can plug it into my motors or not.
I apologize in advance if there's a topic that answers this question. If that's the case, please just link me.Thanks in advance for your help.
SUBSYSTEM CODE
package edu.wpi.first.berserker.subsystems
import edu.wpi.first.wpilibj.command.PIDsubsystem;
public class DriveTrain extends PIDSubsystem (
private static final double Kp = 3;
private static final double Ki = .2;
private static final double Kd = .1;
private Robotdrive drive = new RobotDrive(Robotmap.leftMotor, Robotmap.rightmotor);
private Gyro newgyro = new Gyro(Robotmap.gyro);
private DriveTrain() {
super ("DriveTrain", Kp, Ki, Kd);
public void initDefaultCommand() {
setDefaultCommand(new DrivewithJoysticks());
protected double returnPID(){
return gyro.pidGet();
protected void usePIDOutput(double outpout) {
//Not certain what needs to go here.
COMMAND CODE
package edu.wpi.first.berserker.commands;
public class DriveStraight extends CommandBase (
double setPoint;
public DriveStraight(double setpoint) {
requires(drivetrain);
this.setpoint = setpoint;
protected void initialize() {
drivetrain.setSetpoint(setpoint);
drivetrain.enable();
protected void execute() {
protected boolean isFinished() {
return Math.abs(drivetrain.getPosition() - setpoint <.02);
protected void end() {
drivetrain.disable();
protected void interrupted() {
Unread 01-03-2012, 10:44
Re: Best way to drive straight using a gyro?
This is the code as updated at our last meeting before our regional. We'd really like to get an idea of how well it'd work before we get there:
package edu.wpi.first.ReboundRumble.subsystems;
mport edu.wpi.first.ReboundRumble.OI;
import edu.wpi.first.ReboundRumble.RobotMap;
import edu.wpi.first.ReboundRumble.commands.DriveWithJoys ticks;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.command.PIDSubsystem;
import edu.wpi.first.ReboundRumble.commands.CommandBase;
* @author Developer
public class DriveSystem extends PIDSubsystem {
private static final double Ki = 0.2;
private static final double Kd = 0.1;
RobotDrive drive= new RobotDrive(RobotMap.LeftDrive, RobotMap.RightDrive);
Gyro gyro = new Gyro(RobotMap.gyroPort);
// Initialize your subsystem here
public DriveSystem() {
super("DriveSystem", Kp, Ki, Kd);
setSetpoint(0);
// Use these to get going:
// setSetpoint() - Sets where the PID controller should move the system
// to
// enable() - Enables the PID controller.
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
setDefaultCommand(new DriveWithJoysticks());
protected double returnPIDInput() {
// Return your input value for the PID loop
// e.g. a sensor, like a potentiometer:
// yourPot.getAverageVoltage() / kYourMaxVoltage;
return gyro.getAngle();
protected void usePIDOutput(double output) {
// Use output to drive your system, like a motor
// e.g. yourMotor.set(output);
if (gyro.getAngle() > 1) {
DriveReg(0, output);
if (gyro.getAngle() < -1){
DriveReg(output, 0);
drive.tankDrive(.5,.5);
Unread 01-03-2012, 11:13
Not like a potentiometer. See bolded portions below:
 * Return the actual angle in degrees that the robot is currently facing.
 * The angle is based on the current accumulator value corrected by the oversampling rate, the
 * gyro type and the A/D calibration values.
 * The angle is continuous, that is can go beyond 360 degrees. This make algorithms that wouldn't
 * want to see a discontinuity in the gyro output as it sweeps past 0 on the second time around.
 * @return the current heading of the robot in degrees. This heading is based on integration
 * of the returned rate from the gyro.
float Gyro::GetAngle( void )
Unread 20-01-2017, 17:11
ptoil ptoil is offline
FRC #5401 (Fightin; Robotic Owls)
Rookie Year: 2015
ptoil is an unknown quantity at this point
Why did you use 3, .2, and .1 as your PID gains?
Unread 20-01-2017, 17:39
ProjectZero hasn't posted here since 4 years ago.
Unread 20-01-2017, 17:51
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Note that ProjectZero has not been on Chief Delphi in over a year.
The P, I, and D gains are usually determined through a bit of math and a lot of trial and error once the hardware is running. If you search Chief Delphi on "PID Drivetrain Tuning" you will turn up a few good threads that take you through several schools of how to determine your optimum PID values.
Note that when you add/subtract (or even move) weight to your robot, you will want to adjust (or at least verify) your PID constants.
