Go to Post I tried to convince my team to use the force but no one would listen. - ngreen [more]
Unread 20-01-2017, 16:57
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: looking for flexible shaft coupler for 1/2 inch hex
Originally Posted by yarden.saa View Post
We had last year 775Pro on VP gearbox 3:1 direct drive a hex shaft with vex hex shaft coupler with no problem of vibrations. You are probably going too fast, I don't think you need 18000 rpm for a shooter.
no probably not all that but we are spinning a 2 inch wheel
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 20-01-2017, 16:58
Bruceb's Avatar
Originally Posted by cbale2000 View Post
If you're using a versa-planetary anyways, why not just use a versaplanetary encoder?
because the encoder made for the RS-775 pro is much smaller and I have heard good things about it.
Unread 20-01-2017, 17:12
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Ok, so I think there are a few things you should look at to try and fix the problems in the design rather than patch over them. You should have some reduction coming off of an RS-775. You already have the VersaPlanetary in there, why not change it to an actual reduction? This will vastly improve the accuracy and consistency of your shot anyways. As for the encoder, if you already have the encoder set up for the RS-775, that's fine. But you can also use the VersaPlanetary integrated encoder. It works very well also.
Unread 20-01-2017, 18:28
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
What motor and encoder specifically are you trying to use? Perhaps provide links?
To my knowledge there is no such motor as an "RS-775 Pro"; there is an "RS-775" and a "775 Pro" but these are very different things.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 20-01-2017, 20:39
Tom469 Tom469 is offline
AKA: Tom Riggs
FRC #5402 (Iron Kings)
Rookie Year: 2015
Tom469 is an unknown quantity at this point
For a rotary encoder, I suggest you turn the end of the Hex shaft down to ~ 1/4" and use a piece of 1/4" fuel hose, ~ 1 1/4" in length and use a couple of flat spring clamps to clamp the ends. Then carefully align it. The fuel hose and flat clamps are standard lawnmower items.
The harder mechanical flex couplers transmit a lot of vibration to the encoder, and can cause pre-mature failure. The company, that I worked for introduced a flex coupler then discontinued their use. And, went back to the fuel hose.
Unread 20-01-2017, 22:42
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
<snip>To my knowledge there is no such motor as an "RS-775 Pro"; there is an "RS-775" and a "775 Pro" but these are very different things.
The designation RS-775 is borrowed from Mabuchi Motor Co., Ltd. and it indicates a round, carbon brushed DC motor with a 5-pole, size 7 armature (diameter) and a size 7 housing (length). There are at least four legal motors that satisfy that description:
  • AndyMark's RS775-5
  • AndyMark's RS775-125
  • BaneBots' RS-775 18V
  • WestCoast Products' 775pro
The first two are almost identical. The latter two are much more powerful than the former, but distinct from each other. Any one of them could be called an RS-775 with roughly the same degree of accuracy. It is prudent to clarify, but I believe that the motor in question is a 775pro.
