Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 20-01-2017, 19:45
MMuru MMuru is offline
FRC #0610
MMuru is an unknown quantity at this point
Android to RoboRIO Communication
Hello all,
My team has decided to see what is necessary to use an Android Phone for vision tracking and sending the target information to the RoboRIO. We have been looking through the RIOdroid library (https://github.com/Spectrum3847/RIOdroid). ADB installs fine on the RIO, however, there is a program called SOCAT which is used for port forwarding and virtualization which refuses to install saying that the architecture is incompatible. When we attempt to install it on a RIO with last years image on it, the installer works fine. We have tried downloading various versions of SOCAT, but all of them fail with the same message. Are there any other communication protocols that can be used between Android and the RoboRIO? All help would be appreciated!
Unread 20-01-2017, 19:49
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Re: Android to RoboRIO Communication
The RioDroid library link provided does not work. the ")" counts as part of the link.
The proper link is this
Team 1403: Cougar Robotics (2015 - present)
Unread 20-01-2017, 22:21
Thardro Thardro is offline
AKA: Ethan
FRC #3042 (Cobalt Catalysts)
Rookie Year: 2015
Thardro has a spectacular aura aboutThardro has a spectacular aura about
We have been able to communicate with an android phone using RIOdroid without using SOCAT. By running "adb reverse tcp:3000 tcp:3000" on the roboRIO you can establish a tcp connection between the roboRIO and the phone, so that connecting to 127.0.0.1 on port 3000 on the phone will connect you to port 3000 on the RIO.
Unread 20-01-2017, 22:38
FRC #0610
Could I get some a snippet of what that code looks like? Also does that mean that everything else from the RIOdroid library is functional? Finally, was this tested on the 2017 image of the RIO?
Unread 20-01-2017, 22:49
AKA: Ethan
Rookie Year: 2015
Here is our code that does this on the RIO and you can look inside the vision folder for the rest of our code that handles the connection on the roboRIO (it is almost entirely a copy of 254's code from last year). This is all we have used the library for so I cannot comment on whether the rest is working, however this is enough to send messages back and forth between the RIO and a phone. We have this all set up and working on the 2017 image of the RIO as well.
Unread 20-01-2017, 23:22
FRC #0610
Thank you so much!!
