Go to Post I think I have a warning label saved somewhere on my computer that says "Warning: All photos taken with this camera may be photoshopped" but I keep forgetting to put it on my camera. - MissInformation [more]
Unread 08-12-2016, 10:51
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
[FTC]: Beacon problems
We are having issues with our beacons. At the beginning of the year we bought a set of four beacons and two of them have failed.
One of them no longer powers up at all. Every once in a while you can see the LEDs flash for a brief moment and then nothing. We tried re flashing the firmware but it won't accept it
The other one has the problem where one of the buttons on the field side works but the other one does nothing. The randomizer button also acts as a field side button but its always the same side as the field side button that does work. After a certain amount of time it will also just change automatically. We have checked that there are no shorts and still get the weird behavior We have tried refreshing this one and it says it accepted the firmware but it still operates wrong.
We came up with the conclusion that static might be the cause of this because last night I touched a button and felt a static shock and the light on that side turned yellow. We disconnected power and plugged it back in and it started working again. Before this we were wondering if the way we were powering them was causing the issue but I don't believe it would. We currently power them with a 9 volt power supply so we don't have to waste batteries.
Has anyone seen this before? Is there any fix?
Thanks
Unread 08-12-2016, 11:11
Billfred's Avatar
Billfred Billfred is offline
Re: [FTC]: Beacon problems
Thanks
We at AndyMark have been working on a few reports similar to yours. If you would, drop an email to support@andymark.com and it'll get routed to our engineers working on this.
Unread 12-12-2016, 12:42
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
I can only confirm that we are seeing similar issues. I have no fix other than what you've described. Very scary as an event director as we don't have spares. For my next meet, I'm going to ask teams to bring spare beacons that have them. We already request teams bring spare Cap Balls in case we puncture one or more.
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
Unread 12-12-2016, 13:00
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I can feel this. I was a field manager yesterday, and I think we went through at least half a dozen beacons at the Sunday tournament alone. Fortunately my understanding is that AM has been very responsive when HTK, the MN affiliate partner, has contacted them for support.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 12-12-2016, 14:40
Whatever Whatever is offline
FRC #2502
Whatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond repute
I have a theory on this....
When you use a 9V battery, there isn't a ground path in the beacon. When you use a 9V supply, you introduce a ground path in the beacon. The fields themselves do not have a ground path built into them, so using a 9V supply means all static built up on the field and in the robots eventually gets discharged through the beacons. That's my best guess for what is causing the issues.
I wanted add - I served as queuer and did general field repairs at an earlier event. The tournament started with the 9V being hardwired and 2 beacons went bad during field testing (pretty much as described). At that point all the beacons were switched to 9V batteries and we ran the next two days without any beacons going bad (which was good because we only started with two back ups). I know the event Nick is referring to used a supply.
Unread 12-12-2016, 15:52
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
I volunteered at the Smithville FTC qualifier this weekend in KC. We were scheduled to have 28 qualifications matches and at maximum of 9 eliminations grade. We ended up playing 9 finals matches because of both ties and broken beacons. By the end, we had replaced 11 beacons on our two fields. The FTA there said that they were being caused by static. I'm not convinced that it was entirely caused by static and that all of them were broken. One team had repeatably slammed their robot into the beacons VERY hard, which might have also caused some issues with the beacons. From what I've heard from others, it seems to be caused by the fact that the beacons are designed with metal buttons, and thus the static is going through the beacon main board.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 20-01-2017, 20:12
AmazingSpanoMan AmazingSpanoMan is offline
FTC #9533
AmazingSpanoMan is an unknown quantity at this point
Exclamation Re: [FTC]: Beacon problems
Has anyone heard anything about this? We are desperate at this point. Purchased 4 Beacons 1 dies a week ago and the other three today. I have no clue how this happened or if there is a fix. Now we don't even have one beacon to test our autonomous on which just happens to be a big part of the challenge this year
Unread 20-01-2017, 20:14
FTC #9533
Also, beacon replacements are not available for purchase.
Unread 20-01-2017, 20:19
Billfred's Avatar
If you haven't, please email support@andymark.com with as much information about your setup as you can. We have engineers focused on resolving customer issues with beacons, and emailing there also allows us to document any trends that may develop over time.
