Go to Post There's nothing wrong with the loader [dividing by zero], John just misses us 229'ers and wanted everyone to know :-P - Jay Trzaskos [more]
Unread 20-01-2017, 20:19
Bo8_87 Bo8_87 is offline
Bo8_87 is an unknown quantity at this point
Robot Battery Placement
Hello CD,
Traditionally, my team has always mounted our batteries upright in our chassis. However, this year we are considering mounting it horizontally. Are there any safety risks/harm that comes with mounting it horizontally? Thanks.
Unread 20-01-2017, 21:17
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Robot Battery Placement
They can be mounted flat. No problem.
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
None other than secure mounting. These are sealed lead acid batteries. If you were using a standard lead acid car battery (spillable, also not FRC legal), then you would have to make sure it is upright.
Unread 20-01-2017, 22:11
anushad anushad is offline
FRC #2876
anushad is on a distinguished road
One thing that could be worth noting is changing the battery - it could be harder (probably not significantly, but maybe if there are a lot of other mechanisms near it) to change the battery between matches if it's placed weirdly.
Unread 20-01-2017, 22:13
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The only time orientation matters is charging. You shouldn't charge the batteries upside down, as overcharging can generate hydrogen, and the vents at the top of the battery need to release said hydrogen.
Unread 20-01-2017, 22:21
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
Make sure battery terminals don't hit any metal parts, especially when robot bumps into obstacles. The location should be easy to access and replace.
Unread 21-01-2017, 00:26
Thanks for all your help!
Unread 21-01-2017, 00:39
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Huh. I've never heard that. Is charging batteries on their side still ok? Is the hydrogen still able to vent in that orientation?
Unread 21-01-2017, 01:56
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
They shouldn't be able to. Keep all your battery terminals covered, all the time. Electrical tape is the natural choice to put over the ring terminals and bolts on the battery leads. If you get new batteries and aren't able to put leads on them right away, cover the terminals with tape or caps. It's a really small amount of effort to do, and there's just no sense in taking the risk of shorting a battery on anything.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 21-01-2017, 10:57
Most of the stuff I see says anything but upside down is fine. The issue is that when you're charging lead acid batteries the charging voltage is causing water electrolysis at the same time as the normal charging chemical reaction. A slow charge lets the H and O recombine at the same rate it's generated. Extremely rapid charging and overcharging create H and O faster than it can recombine, so pressure builds up and has to be vented through a pressure regulated valve. There shouldn't be much or any liquid electrolyte in an SLA battery, but charging it upside down would concentrate it at the valve, where it could leak if the valve ever has to release pressure.
So it's an unlikely problem, but completely avoidable by just not charging them upside down.
Unread 21-01-2017, 11:01
If you have the terminals somewhere they could run into something outside the robot, most plastic coverings won't save you. For instance, imagine a battery horizontal underneath a robot last year with the terminals down instead of up. Electrical tape isn't going to stay an insulator long in those conditions. It's only protection against momentary incidental contact, not violent contact or repeated rubbing.
Unread 21-01-2017, 11:39
I am not sure how many teams charge their batteries on the robot, we never did. We chose to replace battery for every match, so ease of replacing was on top of the priority list. We used electrical tape over the heat shrink rap on terminals as cushion (after our run into mysterious issue), so terminals were protected. Electrical tape doesn't have to come out or get loose to cause problems. When battery jumps as a result of robot bumps, if terminals hits metal tubing electrical tape gets hairline cut, it's hard to notice, which may cause short during next bump.
Unread 21-01-2017, 17:55
Ekcrbe's Avatar
MIssin' the MItten
AKA: Erik Boyle
Well sure. You shouldn't design your robot in a way that allows the battery to be subjected to repeated hard impacts, but you also shouldn't leave the terminals exposed in case something ever happens. I think Tungrus meant that the battery would shift within the robot, not come into contact with the outside world. But think, for instance, of a piece of your robot breaking off and landing inside the chassis. It shouldn't short the battery if the two come into momentary contact. Likewise around the shop. Don't handle batteries in an aggressive or unsafe way, but I'd rather have some insulation on the terminals than none.
Unread 22-01-2017, 00:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We mounted our battery vertical our first four years, and last year we used the AM battery mounting kit for the kit chassis, which mounts the battery horizontally. It was in there quite securely (better than most of our home brew solutions), and only required pulling a single bungee off to remove it from the bracket, but it did require moving some other components out of the way to get to the battery. I'm about 98% certain we're going vertical again this year.
Unread 22-01-2017, 10:58
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Is there a way to mount the AM mounting kit vertical on a kit chasis?
#StaySavage
