Go to Post As I told my friend Joe Johnson, just because you aren't around as much doesn't mean that you can just close the book on this chapter, instead - just keep a book marker in this place, so you can remember how to find your way back home - when the time is right. - meaubry [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 20-01-2017, 21:38
webbbt456 webbbt456 is offline
FRC #0456
webbbt456 is an unknown quantity at this point
LabView Install Error
Having problems installing LabView for FRC 2017 on Windows 7 x64 computer that had last years version. We uninstalled last years version first, ran every windows update, added VS2015 runtime x64 and x86. All Firewalls are off. We have tried using the LabView Disc from the KOP and downloading it from NI.
We get the following error:
One or more errors occurred
Installation Failed
LabVIEW 2016
LabVIEW 2016 Real-Time Module
NI Vision Development Module 2016
NI-RIO Support for FRC 2017
Simulation Support for FRC 2017
NI-IMAQdx 16.0
These products failed to install due to missing prerequisites, a system error, or cancellation. Either install these prerequisites or reboot your computer, as appropriate, and then retry this installer. If this problem persists, contact National Instruments support at ni.com/support.
We have successfully load LabView on 2 other laptops. Any help would be greatly appreciated.
