Go to Post As long as the competition gets the attention of someone and drags them in, it doesn't matter how they get there. - Andy Grady [more]
Unread 20-01-2017, 22:58
Bo8_87 Bo8_87 is offline
Bo8_87 is an unknown quantity at this point
What encoder to use?
Hello CD,
We are debating between 2 encoders for our drivetrain, the Grayhill 63R256 and the WCP Dual Output Encoder. We are using custom transmissions, so these will be most likely mounted onto a wheel.
http://www.digikey.com/product-detai...3070-ND/304479
http://www.wcproducts.net/WCP-0110
Does anyone have any recommendations or experience with either?
Unread 20-01-2017, 23:00
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: What encoder to use?
Originally Posted by Bo8_87 View Post
Hello CD,
I would wait on the WCP encoder, It won't be available for a month or so. It'll function similar to an s4 encoder from US digital with a true absolute output as well.
R.C.
MadTown Robotics Team 1323
Unread 21-01-2017, 00:57
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Any encoder that has locking connectors is a huge plus.
Good enough is the enemy of anything great!
team 1671
Unread 21-01-2017, 01:16
Oblarg Oblarg is offline
AKA: Eli Barnett
The grayhill encoder works exactly as you'd expect it to, and is a nice, simple solution.
"The breakfast of champions!"
Unread 21-01-2017, 08:09
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
We have used the grayhill ones for several years and they work very well (even the 128s are good enough for most drive applications). As mentioned, though, they do not have locking connections. We use hot glue for these.
If you are using Talon SRX's for your drivetrain, there is no need to have the dual output since the Talon will keep track of position for you. Other than swerve drive wheel angle, I don't know of an application for an absolute encoder on a drivetrain.
I am probably missing something, but I didn't see a link to complete tech specs for the WCP encoder. I would not recommend any encoder where we could not get to full tech specs (pin outs, signal specs, etc.) on-demand and easily.
