Android to RoboRIO Communication
Hello all,
My team has decided to see what is necessary to use an Android Phone for vision tracking and sending the target information to the RoboRIO. We have been looking through the RIOdroid library (https://github.com/Spectrum3847/RIOdroid). ADB installs fine on the RIO, however, there is a program called SOCAT which is used for port forwarding and virtualization which refuses to install saying that the architecture is incompatible. When we attempt to install it on a RIO with last years image on it, the installer works fine. We have tried downloading various versions of SOCAT, but all of them fail with the same message. Are there any other communication protocols that can be used between Android and the RoboRIO? All help would be appreciated! |
Re: Android to RoboRIO Communication
We have been able to communicate with an android phone using RIOdroid without using SOCAT. By running "adb reverse tcp:3000 tcp:3000" on the roboRIO you can establish a tcp connection between the roboRIO and the phone, so that connecting to 127.0.0.1 on port 3000 on the phone will connect you to port 3000 on the RIO.
Last edited by Thardro : 20-01-2017 at 22:23. Reason: Port # was showing as emoji |
