Go to Post Let's just say that I am old enough to... - dlavery [more]
Unread 20-01-2017, 23:45
jinggeorge jinggeorge is offline
FRC #0128
jinggeorge is an unknown quantity at this point
Minimum requirements for driver station laptop
My team already has a laptop for programming. We don't like to use it during competition since it isn't cheap, and it could break if someone gets too excited. (It has happened before.) For matches in the past, we have used an E14 classmate, but it seems to have some issues that we likely cannot overcome. We want to find a small, cheap laptop to replace it, that will not be used for programming. This laptop would only be used during matches. What are the recommended minimum properties of a laptop for running the robot during competition?
Unread 21-01-2017, 21:58
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: Minimum requirements for driver station laptop
A laptop that can run the driver station.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 21-01-2017, 22:04
niklas674's Avatar
niklas674 niklas674 is offline
Mecanum+drive=A bad idea
FRC #0701 (Robovikes)
Team Role: CAD
Rookie Year: 2015
niklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of light
This is very helpful.
My views do not represent the views of my team
Unread 21-01-2017, 22:12
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Wow! Very helpful!
Anyway, I'll give you some actual advice and not just a snarky reply.
I'd recommend the following:
Processor: i5 or i7 from Intel. The i5 should be sufficient if you just want to use it for the driver station. If you'll be running GRIP or some other sort of vision processing software go for the i7.
RAM: 8gb or 16gb. Also dependent on the use case. 8gb should be fine, but go for more if you want to run vision stuff.
Storage: SSD. A solid state drive will make it way faster for the laptop to load and it's a huge performance boost.
Other stuff: Good battery helps when working in-between matches.
Hope that helps!
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 21-01-2017, 22:21
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Originally Posted by bkahl View Post
A few recommendations for ALL Drive station laptops after spending a few seasons in High School behind the glass.
1) SSD. Reasons stated above.
2) Put Drivers Station and any dashboard you need in Startup. A reboot with an SSD and these files booting right away will allow connection and reconnection to a robot MUCH faster.
3) Touchscreen. While this may be a stretch for some- it can be really simple for enabling and disabling for ANYONE (not everyone knows hotkeys) and also makes log viewing really quick and easy.
4) NOTHING unnecessary on the laptop. There's no reason to have browsers or anything if you never connect it to the internet. (Never connect a DS to the internet......)
5) Webcam- while it's likely to never come back... You don't want to be the only one unable to do a 'Cheesy Vision'-esque program for auton if it does and your USBs may be getting full.
6) at least 3/4 USB ports. Allows up to 3 joysticks/controllers to be connected directly to the laptop while maintaining quick tethering via USB.
7) Ethernet Port- obvious
8) use it ONLY as a drivers station- kind of ties in with 4, but keeping the drivers station pristine will allow for peak performance.
9)Good Trackpad- a good trackpad will make quick troubleshooting easier and will make every FTA or CSA that has to help you much happier.
All of these are nice but the most neccessary ones to me are 1,2,4,6,7
At the end of the day, I don't think RAM or Processing power is as important as some of these and these can all(besides maybe touchscreen) definitely be found in a low budget, refurbed laptop.
Also- don't be afraid to buy a laptop for upgrade. I'm sure there's a student on most teams who can upgrade RAM a bit or throw an SSD in a laptop.
Inb4 someone red dots me for quoting myself
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 21-01-2017, 23:12
EmileH's Avatar
EmileH EmileH is offline
starting to feel the burn
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Is the i7 really necessary for vision processing? At a certain point isnt the latency the limiting factor in process speed?
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 22-01-2017, 00:09
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
In addition to the above advice, I recommend doing a fresh install of Windows. You don't want any OEM crapware interfering with the driver's station.
Use this tool to create a bootable USB drive of Windows 10.
Also, the difference an SSD makes cannot be understated. Most cheap laptops won't come with one, but you can get 250GB ones for around $80 now. Just make sure the laptop has an upgradable hard drive. An SSD also won't break if it gets knocked of the driver's station shelf.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 23-01-2017, 12:19
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Originally Posted by frcguy View Post
Wow! Very helpful!
Vision processing is heavily single-threaded. Use a high-clocked i5 like the 7440HQ or 7440EQ.
8GB of RAM is plenty. GRIP only uses ~240MB.
But for absolute minimum specs, pretty much any i3 + 4GB RAM + SSD will be fine.
WPILib
GRIP, RobotBuilder
Unread 23-01-2017, 12:34
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #2898 (The Flying Hedgehogs), FRC #1510 (Wildcats)
Philip Arola is an unknown quantity at this point
A 1080p screen is severely underrated for driver stations. When you start making advanced dashboards it will be indispensable.
In this day and age, you have no excuse to at least get a 128 GB SSD. They're fairly cheap, and hard drives have been the first point of failure for our driver stations in the past.
Abundant USB ports and an Ethernet port and an absolute must.
The processor and RAM really depend on your vision code. The other posters seem to have nailed those specs.
Really what you want is a Thinkpad. They're solid, and generally have the features that a drive station needs. Mainly solid.
/shill
Cunningham's Law: The best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.
Unread 23-01-2017, 13:36
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
While we risk being thrown out of the club, we use a lowly Acer Aspire One netbook for the driver station. Our vision processing is done on the robot.
