Re: Robot Battery Placement
They shouldn't be able to. Keep all your battery terminals covered, all the time. Electrical tape is the natural choice to put over the ring terminals and bolts on the battery leads. If you get new batteries and aren't able to put leads on them right away, cover the terminals with tape or caps. It's a really small amount of effort to do, and there's just no sense in taking the risk of shorting a battery on anything.
I am not sure how many teams charge their batteries on the robot, we never did. We chose to replace battery for every match, so ease of replacing was on top of the priority list. We used electrical tape over the heat shrink rap on terminals as cushion (after our run into mysterious issue), so terminals were protected. Electrical tape doesn't have to come out or get loose to cause problems. When battery jumps as a result of robot bumps, if terminals hits metal tubing electrical tape gets hairline cut, it's hard to notice, which may cause short during next bump.
We mounted our battery vertical our first four years, and last year we used the AM battery mounting kit for the kit chassis, which mounts the battery horizontally. It was in there quite securely (better than most of our home brew solutions), and only required pulling a single bungee off to remove it from the bracket, but it did require moving some other components out of the way to get to the battery. I'm about 98% certain we're going vertical again this year.
Only if you have enough end sheet left, and then it still wouldn't be convenient. The AM kit takes advantage of the 3" width of the "C" on the end sheet being very slightly larger than the battery thickness, and secures the battery in that space.
