Go to Post What no one knows is that I’m actually wearing fishnet stockings under this gown… as soon as they finish taking all of these darn photos I’m going to show Dave and Amanda who really has the best legs in FIRST!!! - MissInformation [more]
  #31   Spotlight this post!
Unread 09-01-2017, 10:15
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: WPILib Suite 2017
Originally Posted by snekiam View Post
I'm probably confused by the maven repo structure, but I don't see anything from 2017 under http://first.wpi.edu/FRC/roborio/maven/release/. Am I looking in the wrong spot?
You have the correct link. The last modified date for folders is a little weird. It only updates when we create the folder, not when its contents are updated. If you dig down a little bit you should start to see dates that make sense.
  #32   Spotlight this post!
Unread 10-01-2017, 17:11
arshacker arshacker is offline
arshacker has a little shameless behaviour in the past
We usually work in cpp in eclipse-luna. Have problems with build not finding
cantalon and cantalonsrx header contents even though we included the new ctre locations. By the way..where is kVbus enumeration now.
No problems with java. Have written sample file with no errot msgs.
  #33   Spotlight this post!
Unread 21-01-2017, 07:37
AKA: אוסטין
WPILib Suite 2017 Version 2017.2.1 has been released! You can update by opening Eclipse and clicking Help -> Check for Updates.
Release Notes:
WPILibC & WPILibJ:
  • CameraServer.startAutomaticCapture() will now automatically increment the USB device number (e.g. 0, 1, 2, etc).
  • Removed NetworkTables-driven camera settings (could prevent camera settings changes from taking effect due to dashboard caching)
  • Fixed solenoid allocation error message
  • Documentation updates
Eclipse Plugins:
  • Fix RoboRIO image version detection in presence of EOL in configuration
  • Improve IP address resolution during deployment
  • Excluded sources and javadoc JARs from user libs when building
  • Java and C++ debug deploys now deploy libraries
  • Added option to disable automatic library management
CSCore:
  • Fixed exception on camera creation when camera is not plugged in
  • Added properties setting capability through web server
NetworkTables (NTCore):
  • Documentation fixes
RobotBuilder:
  • Added support for ConditionalCommand
