Go to Post The most important piece of advice I can give is have someone assigned to pay attention to the batteries. You cannot imagine how many teams end up saying "I thought you were charging the batteries..." - RoboMom [more]
Unread 20-01-2017, 16:33
FRCTeam2988 FRCTeam2988 is offline
FRC #2988
FRCTeam2988 is an unknown quantity at this point
Unable to deploy code to Roborio
Currently we are unable to deploy code, even though we can connect when we navigate to the RoboRio's website. This is what we get
C:\Users\Team 2988\wpilib\java\current\ant\build.xml:293: com.jcraft.jsch.JSchException: Algorithm negotiation fail
full deploy message
Buildfile: C:\Users\Team 2988\workspace\testie\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\Team 2988\workspace\testie\build
   [delete] Deleting directory C:\Users\Team 2988\workspace\testie\dist
compile:
    [mkdir] Created dir: C:\Users\Team 2988\workspace\testie\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar;C:\Users\Team 2988\wpilib\java\current\lib\NetworkTables.jar;C:\Users\Team 2988\wpilib\java\current\lib\opencv.jar;C:\Users\Team 2988\wpilib\java\current\lib\cscore.jar to build
    [javac] Compiling 5 source files to C:\Users\Team 2988\workspace\testie\build
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/buttons/Button.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac]   It is recommended that the compiler be upgraded.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/IterativeRobot.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/command/Command.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/command/Scheduler.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/livewindow/LiveWindow.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/smartdashboard/SendableChooser.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/smartdashboard/SmartDashboard.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/RobotBase.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/command/Subsystem.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/NamedSendable.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] warning: C:\Users\Team 2988\wpilib\java\current\lib\WPILib.jar(edu/wpi/first/wpilibj/Sendable.class): major version 52 is newer than 51, the highest major version supported by this compiler.
    [javac] 11 warnings
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\Team 2988\workspace\testie\dist
    [mkdir] Created dir: C:\Users\Team 2988\workspace\testie\build\jars
     [echo] [athena-jar] Copying jars to build/jars.
     [copy] Copying 4 files to C:\Users\Team 2988\workspace\testie\build\jars
      [jar] Building jar: C:\Users\Team 2988\workspace\testie\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-2988-FRC.local
Unknown host: roboRIO-2988-FRC.local
     [echo]  roboRIO not found via mDNS, falling back to DNS
Unknown host: roboRIO-2988-FRC.lan
     [echo]  roboRIO not found via DNS, falling back to static USB
     [echo] roboRIO found via static USB
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
  [sshexec] Connecting to 172.22.11.2:22
BUILD FAILED
Total time: 4 seconds
Unread 20-01-2017, 17:50
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
soundfx is an unknown quantity at this point
Re: Unable to deploy code to Roborio
As the second to last line before the build fails says, check that you have installed java on the roborio. I think this must be done after every time you reimage or update the firmware for a roborio. If that doesn't work, try uploading to a different roborio if you can, and let us know how it works.
"I got 99 problems but 0.999 ain't 1."
~Orteil
Unread 20-01-2017, 19:17
Psychicowl's Avatar
Psychicowl Psychicowl is offline
FRC #3039
Psychicowl is an unknown quantity at this point
Yeah my team just ran i into this same error I had to reinstall Java on my roboRio
Unread 21-01-2017, 09:52
FRC #2988
I'll try re-installing java, however we had already try'd that, hopefully we have better luck this time.
Unread 21-01-2017, 10:06
What version of eclipse and JDK are installed on your computer. It looks like one of them is old.
Unread 21-01-2017, 10:08
FRC #2988
Reformatted Rio using
C:\Program Files (x86)\National Instruments\LabVIEW 2016\project\roboRIO Tool\roboRIO_ImagingTool.exe
Then flashed Java Using
C:\Users\Team 2988\wpilib\tools
I re-downloaded the JRE to make sure I got the correct JRE, however it still won't deploy and the error message is still the same.
Unread 21-01-2017, 10:10
FRC #2988
That fixed it, I had Eclipse pointed to an older jdk, what in the error message tipped you off so I can fix it next time?
Unread 21-01-2017, 10:24
FRC #2988
Nevermind just re-read error message and saw the 11 warnings that JDKS are out of date.
Unread 21-01-2017, 20:16
GoldenGollem's Avatar
GoldenGollem GoldenGollem is online now
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
Another thing my team has found, is that you will get this error if you are connected on the 5G radio connection. You must use the regular radio connection.
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
